will someone please think of the 400 kids who didnt get to play sport in caulfield due to lack of parks
http://www.theage.com.au/victoria/the-public-space-that-people-didnt-know-existed-20160220-gmz66o.html
a mate just asked me about a "stage 2" kit for my car
Goodbye cruel world
LOL
it is an issue. they have effectively built a racetrack around public land and are not paying appropriate rent for it because the land rests in a trust of which 40% of the controlling vote are members of the MRC.
we dropped in on the way past and it's a fair shithole and could be used far more effectively.
im not defending the racecourse members club, just seemed silly to suggest the space could be used for childrens sporting clubs and that 400 kids missed out on playing sport
</script>B0QQOmSIgAAePTI.jpg&&0){for(var>
Can't comment as it may or may not be true, but there are a LOT of ovals in that area
side note... we drove past a new outdoor waterpark just near there that is under construction and looks f**king awesome
whos got the pics of martin putting his car into the wall? i want to show the kid that works for me how he may die.
https://picasaweb.google.com/100203254234701302909/200sx02#
http://youtu.be/JjzhqlnG-Wo
Basiclly I did everything stupid you can do.
That was 100% my stupidity.
I've done a bunch of driver training for newbies first thing I tell them you never set a record lap first thing in the day.
Take it easy warm into the track and then start pushing it.
So first thing on a 2 day track da, on a cold greasy track with cold semis I hit the throttle
Don't blame the car.
On a plus note car looks crap but still straight and still is happy doing laps and or limiter bashing on skid pans.
I knew tassie was having electricity issues since December, and had heard things were being kept a bit hush hush.
Dams there are under 15% capacity and apparently using around 1% a week, supposedly they can run to a theoretical 6.5% but has never been done before. A few big industries have been asked to shut down and apparently are being compensated. That, plus big back-up generators are being put online would cost a fortune. Hiring a big-ass generator is costing $20mil and will cost $11mil per month to run. ouch.
http://www.premier.tas.gov.au/releases/energy_supply_update
Over 300MW of power comes from wind, which apparently operates at 40% capacity on average.
Temporary diesel and gas generators are being organised or have already been turned on, and a 200MW temporary generator puts into perspective how small a part wind really plays. You cant rely on that shit in an emergency!
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
