Birds my way to get that turbo rush of power out of nowhere is to get dat dere foot turbo lag makes you realize that it pulls, either that or sit 4000rpm then stomp the throttle for that instant throwback.
That awkward moment when a walkinshaw gts goes you off the line when you've just started driving and tyres are rock icey cold, skated all the way up Blackburn road near Monash playing catch-up. Then on roll he bitched out when I was aware
so... you lost?
I see 88E is still on a stride..
https://www.google.com/?gws_rd=ssl#safe=off&q=88e+share+price
Depends which time span you're looking at...
Daily is fine, everything else.... not so much.
88e train de-railed, goodbye old friend $
rip $$
Hello darkness my old friend...
Anyone invested should be using the opportunity to buy more while cheap; share price down but the fundamentals have not changed, only improved. DYOR, not financial advice blah blah
Edit: London up so far today; this might have reached its floor
yeah it had fallen further tho so needs to stabilize.
that said with the News from Qatar over the past couple of days new Oil deposits are not making money.
Iran is Fkning the market with oil
it prob has LONG term chance as you said but nothing short term as far as I can see,
They can't hold that up for too long; literally selling themselves out of a future like the Saudis. Oil price has been making a very good recovery and ultimately it's a finite resource that the world will still need for decades. They aren't making any more of it, so whether a year or 5 years this reserve we have of a billion barrels plus is quite something.
As for little 88E, at the recent investor presentation they've said at current price of oil it is profitable; they have joint venture offers on the table, but want a better deal/s to maximise value for shareholders (themselves included), so will continue proving it up to get more interest and better leverage. Personally I'm not interested in the short term share price for any reason other than to buy more shares for cheap, but recovery does help with new traders who aren't used to seeing their money in a paper loss.
2-3 days ago .050 was the 'new floor'
Test of time - this "floor" may not last either...could go back up to .050 or could sink down again. Need a good few weeks of averages to find out where the real floor is. Honestly don't think it has one, it's too volatile and there's too much happening with the company. Seismic due in June and at any moment a joint venture could drop and be a game changer. Lock your shares in the bottom drawer.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
