nice find, another tip I heard was to buy their store shelving for garage racking. They will probably let the shelving go for nothing in comparison to buying from Bunning's.
I just bought 4th gen Apple TV. Real nice piece of kit.
I think it's an option on the ID18s as there's the light on them but reviews say not built in.
Just opened one doesn't look like it has wireless module, could just get usb wifi doe
And yer 4GB DDR3 1600, sata 3 80gb intel ssd - another SODIMM spot empty, I can chuck more in I guess from my stash too.
They also threw out a perfectly fine 32" tv which my co-worker grabbed.. just no stand on it so has to be mounted on wall or something
Edited by UNR33L
The downfall of DSE has probably been the most beneficial event of the year for VWL
Loving my Logitech bluetooth / nano USB receiver headphones with mic. They power on through the charge cable too so never run out of battery.
well we're clearly not benefiting from 88e
  • Like 3
Found some mini PCs that dick smith were throwing out (Zotacs) managed to get 3 of them out of their bin, came with intel SSDs too.. linux for their promotion screens.. will format and put windows on.. should be able to sell at least $200 each pretty easy. #winning
Anyone want a HTPC? :P
#makingmy88e$back
How are they as HTPC? Had a quick look at reviews and people seem to have some heating issues?
I love people doing reviews of HTPC's and they talk about heat issues / slowdowns after using it for an hour. Then you see that they've got it in an enclosure under the TV sitting on top of the vents of their amp with zero airflow.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
