Basing .035 on the recent new share release. That's what they offered the big boys so this what I base my roving off
Seems I was correct...now to see what it does..
Considering they sold more for .031 I think will bottom out around .033 and then I might think about some
You don't get to call two different floors...pick one that it will stabilise at.
I can't see much support in the buy side, only 12 million shares between current price and 2 cents...and there is heavy manipulation going on with 15 million share orders being traded back and forth. In auction it is being dragged down one pip at a time each day. I cashed out and will be back in when it starts climbing again. Got sick of watching profits piss away again. Still confident it's a great long term prospect but missing out on acquiring more shares for the same money if I don't try to buy in lower as it sinks.
I'm gonna say 2.8
I hope it doesn't, but our last capital raise to private investors pulled the share price down just below the share issue price. Wouldn't surprise me if it happens again.
On the plus side can pick up cheap shares.
I'm gonna say 2.8
Think you called 5.0 (may have been 4.0) as the floor....
Yep I was wrong...but how long should it stay there before you can call it a floor, cause it hung around that for weeks.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
