Basing .035 on the recent new share release. That's what they offered the big boys so this what I base my roving off
Seems I was correct...now to see what it does..
Considering they sold more for .031 I think will bottom out around .033 and then I might think about some
You don't get to call two different floors...pick one that it will stabilise at.
I can't see much support in the buy side, only 12 million shares between current price and 2 cents...and there is heavy manipulation going on with 15 million share orders being traded back and forth. In auction it is being dragged down one pip at a time each day. I cashed out and will be back in when it starts climbing again. Got sick of watching profits piss away again. Still confident it's a great long term prospect but missing out on acquiring more shares for the same money if I don't try to buy in lower as it sinks.
I'm gonna say 2.8
I hope it doesn't, but our last capital raise to private investors pulled the share price down just below the share issue price. Wouldn't surprise me if it happens again.
On the plus side can pick up cheap shares.
I'm gonna say 2.8
Think you called 5.0 (may have been 4.0) as the floor....
Yep I was wrong...but how long should it stay there before you can call it a floor, cause it hung around that for weeks.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
