I had koyo and had an asi. Asi warped like a mofos over 3-4yrs but did not leak. Koyo is just better. Do you want to overheat when giving it a ton on a hot day or would you prefer to never worry?
Lol will never buy another Koyo.. Split down the centre and I cooked my engine, no thanks jeffrey!
Keep in the car ;)
Can't count the number of times my tools have come useful in various situations out in a 20+ year old car. This one fits perfectly in the footwell behind driver; zero movement.
  • Like 1
I used to have a toolkit in the back of my 33, passengers would say "Are you expecting it to break down?".
Very similar to them spotting a in-car fire extinguisher, and then asking "Are you expecting it to catch on fire?"
Cuts me real deep man.
Better to have it and not need it! Anyone new hopping into my car, I explain how to pull out the extinguisher...shitful odds of them ever needing it, but Paul Walker could have used one lol
A life vest is located in a pouch under your seat or between the armrests. When instructed to do so, open the plastic pouch and remove the vest. Slip it over your head. Pass the straps around your waist and adjust at the front
  • Like 3
Pull on these tabs to inflate the vest. For further inflation, blow into the mouthpiece.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
