Both of you cherry picking... wouldn't expect any less from mexicans.
Down 10% for the day.... Flying
if you're looking for a longer term play that 800k may be worth buying into the dip first up, otherwise keep it in your back pocket.
You should note that just after I posted this it dipped to 3.1c before bouncing to 4.0 and settling in around 3.5...lets see what the hour of power holds.
Wouldn't take any advice from jas bloke said stay out of property 6 years ago... That was wisdom worth sharing [emoji23]
I did sell out then.
Doesn't mean I stayed out.
That's suggesting we didn't.
I've been in and out of the market a few times since.
Few hundred K been made.
How much you made on 88E Birds?
Must be closing in on a dollar by now
Made a few cents last week but I had to pay CGT on them. My f**king nephew bought a controlling stake in the company!
you have not separated the home network to a General access and a internal?
Set up a pair of routers give her wifi to the external one and your on the internal with the NAS/important systems?
thought you were a sys admin.
on that note decided to do my CISSP any one recommend some decent training companies for it?
Lol can't do VLANs with my home hardware and couldn't really be stuffed.. she needs access to the NAS for her downloads too anyway :P
Plus she uses my HTPC to do it all anyways
Don't know much about who does CISSP but CBTnuggets were good for the cisco stuff I did
Trends suggest mohsen will sell them at a stupidly low price, which is great for Greg, however trends also suggest they will spontaneously combust once in Greg's posession... which is not so great for Greg
Thus SAU equilibrium is maintained, otherwise me dealing directly with Moh would result in luck and bad decisions dividing themselves by zero
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
