Work site gets shut down until further notice... Have to hang around to do pointless tasks to appear busy. Urge to bail and watch nba at a bar rising.
Never even watched a game, but should be pretty exciting
Work cover only get involved if someone is injured. They suspect a (potentially) common defect. This is 1 week after we got the all clear from some random tests they did, it was always a crock of shit.
Most likely theyll line up a bunch of shipping containers and use that as a makeshift tunnel/blastwall so I can walk to a building in the yard. That'll take a few days. In the mean time I'm hoping Martin sends me his foxtel login details so we can stream the game.
Ahhhh the old shipping container tunnel trick...
http://www.heraldsun.com.au/news/opinion/andrew-bolt/the-case-for-voting-in-bill-shorten-as-prime-minister-and-removing-malcolm-turnbull/news-story/8260b3ac9ead7e2acd24a64f1e601192
LOL
It's amazing either how naive or genuinely stupid he is.
Reading that he clearly bases his entire political ideology on "leftists will ruin the country even when they are liberal party members" and that there is some form of correlation between how "right" someone is and their economic management abilities...
It's almost like he doesn't realise the country is run by a party, not a single person
Just heard an anti-Turnbull ad on the radio spoken by the ETU...had absolutely nothing to do with unions...or electricity for that matter.
Sex party gets my vote again; at least they stand for somethig tangible and desired
The liberal add with the fake tradie is freaking atrocious.... although no-one is going to overtake Bob Katter on bad adds this election
  • Like 1
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
