Roy and HG? Is that some kind of law firm or something?
Who let these guys on the radio? It needs canned laughter so at least I can tell when it's supposed to be funny
I f**king hate R&HG
Yes, you yell comically at things... We f**king get it.
  • Like 1
On 8/12/2016 at 8:10 PM, Jonnoo said:
How many people living under the body corporate
$40k each must be a big problem lol
hang on, you hate something...that does not seem normal.
how much trouble am I going to get in when I buy katie a ticket to bathurst for our anniversary?
16 minutes ago, joeyjoejoejuniorshabadoo said:
I f**king hate R&HG
f**k its hard trying to work out wtf is goin on with ur car
http://www.sau.com.au/forums/index.php?/topic/466284-Help-id-this-turbo
??? Didn't I say it was a 2871 like 2 weeks ago?
Leave the nistune in it, get it tuned to 20psi and be on your way.
I was running 20psi on my hks2530.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
