I told you what you should do if you were gonna mod a 34 sedan or Stagea, Moh....
(the answer is: Don't)
Or if you must, buy someone else's project, the bigger the project the bigger the savings.
15 minutes ago, Birds said:
Yeah it's been awesome, am very lucky. I still think the share is ridiculously undervalued given the company prospects and asset potential, which is why I haven't sold out. Just gotta think of the profits as reinvestment instead of taking it out.
88e is doing a good job of flying under the investment radar, which will send it into orbit if/when we cop good news and mainstream media starts reporting it. That's pretty much how it ten bagged last time.
I'm still in the red, bought in too late :P
37 minutes ago, admS15 said:
Sell it, buy autech 260 rs
i got this for cheap, like, your asking price is 6 times what i paid for this greg haha.
43 minutes ago, Leroy Peterson said:
Has it got ecu? How much can you get ecu? Injectors/exhaust/intercooler/hi-flow then be done. Don't touch it after that.
nah, just tein coil overs
its a series 2 so, neo motor.
is really neat so just thinking nistune, injectors, highflow and keep the stock side mount for maximum surprise.
  • Like 1
I'm gonna disagree with this.
I've rebuilt every aspect of the pulsar minus the gearbox (stay tuned for that one).
A few reasons why it was a bad choice:
Seller was asking a lot and very firm on price and extra parts.
70% of the professional work done was super poor. It worked and was hidden, but not good enough to anything beyond occasional road duties.
Hindsight: build from the ground up and learn to do it properly in the process. Or better yet, start with another's project that has some goodies THEN tear it down and remove all the shit.
True, its probably best you can either a) Vouch for the car/owner and b) Absolutely know what you are looking at.
It can obviously burn you badly, but if you know what you are doing its the way forward.
However usually done through having been burned in the past, but hey 99% of people here on SAU will know what they are doing regarding other people's projects and know when to spot a bad apple
Clearly you haven't read any of the OP posts in the modifications area, or been anywhere near the facebook group.
OK...I'll pay that.. It is pretty clear a lot of the Facebook group queries certainly consult FB before google..
It's so true but makes zero sense. Maybe the day people can't be bothered responding on fb will be the day people stop asking before Google.
1 hour ago, joeyjoejoejuniorshabadoo said:
I don't know if this has been addressed before... But why the f**k does Mohsen now put every post as a spoiler alert?
because im here to spoil your lives
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
