Turn boost down. That will also work. f**k it, just remove the turbo altogether. LOL
Yeah who needs the turbo just takes up space really.
Maybe if i remove it my mrs will stop saying 'stutu' every time i change gears
  • Like 1
1 hour ago, Jonnoo said:
got back to the mrs about 15 min ago
Asked a vietnamese resteraunt for a shifter and he brang me a spoon... (Seriously)
This is the 2nd time ive blown a hoseclamp off.. What causes this!?
Popped a coolah uleh
  • Like 1
so maybe I'm an idiot.
but could you not just push the hose back on the pipe then baby it to somewhere you could get a spanner from?
Keep it sucking not blowing....ie keep off boost and it would run?
seems better than sitting on the side of the road for hours?
Never tried this so could be very very wrong....
On 8 September 2016 at 6:48 PM, Jonnoo said:
I just cut about 50mm off the bottom opening where the cooler would be (if i had one) and it went straight on
Lol the mob who makes them said i have to cut the reo, f*k that!
Where u from? After work err day and sundays I don't normally do much
Pm sent
  • Like 1
The person you bought the engine from should know, I never got asked for the Rego for the engine that I provided, ever. They just ran the number to make sure the engine wasn't flagged as stolen.
Have changed engine numbers at Vicroads like 4-5 times now. Never once got asked for the rego of the car the engine came from.
Also no reason to remove Nistune ever, so the best way to remove it is not remove it.
  • Like 1
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
