Turn boost down. That will also work. f**k it, just remove the turbo altogether. LOL
Yeah who needs the turbo just takes up space really.
Maybe if i remove it my mrs will stop saying 'stutu' every time i change gears
  • Like 1
1 hour ago, Jonnoo said:
got back to the mrs about 15 min ago
Asked a vietnamese resteraunt for a shifter and he brang me a spoon... (Seriously)
This is the 2nd time ive blown a hoseclamp off.. What causes this!?
Popped a coolah uleh
  • Like 1
so maybe I'm an idiot.
but could you not just push the hose back on the pipe then baby it to somewhere you could get a spanner from?
Keep it sucking not blowing....ie keep off boost and it would run?
seems better than sitting on the side of the road for hours?
Never tried this so could be very very wrong....
On 8 September 2016 at 6:48 PM, Jonnoo said:
I just cut about 50mm off the bottom opening where the cooler would be (if i had one) and it went straight on
Lol the mob who makes them said i have to cut the reo, f*k that!
Where u from? After work err day and sundays I don't normally do much
Pm sent
  • Like 1
The person you bought the engine from should know, I never got asked for the Rego for the engine that I provided, ever. They just ran the number to make sure the engine wasn't flagged as stolen.
Have changed engine numbers at Vicroads like 4-5 times now. Never once got asked for the rego of the car the engine came from.
Also no reason to remove Nistune ever, so the best way to remove it is not remove it.
  • Like 1
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
