12 minutes ago, Mohsen said:
who have you guys used for vehicle freight? non running
Prixcar - but that was a running car.
Else Facebook search towing companies. Plenty of small privates on drift sales etc
1 hour ago, UNR33L said:
Pretty similar yeah.. probably why it's still so popular
Funnily going from 1.6 to source and now CSgo I didn't notice much difference, but when you look back on the older titles graphics it's changed heaps. Can't believe I used to play 1.1
34 minutes ago, Jonnoo said:
Depends where from
I got a shell towed from Cranbourne to dandenong by a mate
Did you own the vehicle?
5 hours ago, Leroy Peterson said:
results aren't due until late October/early November. buckle up your seatbelt dorothy... cause the price, is going bye-bye.
latest?cb=20120731203342
Obscure Matrix reference? Really?
5 minutes ago, Leroy Peterson said:
ive been revisiting 90's industrial/goth stuff lately. like John Travolta's haircut in Swodfish
Or the chameleon TVR Tuscan they fire an FN Minimi machine gun from...
Don't forget Fifth Element, Demolition Man and They Live...though I think that was 80s...and not even related...but Roddy Piper...
Toxic Avenger
sounds like 2 guys were in a decent accident at winton over the weekend. they got airlifted from the track. neither had ambulance coverage...
people are chipping in and doing fundraisers to help cover the cost. Discuss.
Obviously its terrible, im glad theyre making a full recovery. I'm not surprised, but I also think its pretty silly that people will fork out for all the expenses that come with tracking a car yet not have ambulance coverage, or at least some sort of health insurance. or is this some of that $60 helmet - $60 head sort of analogy time?
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
