Better at having a hand controller? I don't think so
I have a blitz rvit which is a consult port lcd display. Shows all the oem sensors & works with nistune.
Nistune now has flex fuel option so allows even more options
4 hours ago, Mohsen said:
lets talk ECUs
i was going to big single the sedan and go haltech and all that shit but since ive canned it, im thinking about going for a -5 set up now, and obviously PFC again.
i know chris is going to say PFC, so is matt.
yalla. discuss
Do you need an ECU if its never running or driven?
1 hour ago, Leroy Peterson said:
wait, is -5's for the GTR or the sedan? whats happening with the sedan?
but seriously, just dont touch the GTR. leave it, let it appreciate. the less you drive it, the less repairing it will need.
now get some wheels for the stagea
http://page17.auctions.yahoo.co.jp/jp/auction/v467805801
for the GTR, just gonna repair it and have a nice 330ish kw cruiser.
the sedan is being stripped and put into storage.
may come back soon, may come back in like 10 years, i dont know. nothing on the cards for it atm.
motor, front end parts and the nice interior pieces will go into the R.
1 hour ago, Kinkstaah said:
But I carry a laptop and can fully tune my car wherever I go, with better functionality than a hand controller :P
well I carry punch cards in my glovebox so I can change settings on my powerfc
  • Like 1
Urgh....
Did laugh at the end where he yells "Watch your foot" to the girl... but there's no way that the tyre would have even toucher her foot. Would have gone straight over the top of it.
Jesse Streeter?
@luke gtr @Birds Now's your chance to have that camaro you've aaaaaaaaallllways wanted
http://www.carsales.com.au/dealer/details/Chevrolet-Camaro-/OAG-AD-13503676/?Cr=0
Very nice, but a little too modded for one that id own.
6 hours ago, Kinkstaah said:
Or you could Nistune, which is better in literally every way.
Lmao its f**king not. Stop spreading rubbish. You wouldn't have to carry around a laptop to "fully tune your car wherever you go"  if you had a PFC instead of Nistune.
9 minutes ago, Borci88 said:
4th Gear is not removable on Skyline boxes.
Just got this from UK forums
"4th gear is the input shaft effectively. Select 4th and the input shaft is locked to the main shaft and drives straight through at 1.00 ratio - most efficient gear in the box, lay shaft is bypassed"
So stock 4th would be pretty strong then?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
