I bought bout 8k of motorbike on a credit card before, didn't have any surchages
Since getting Amex I use that bitch for everything whenever I can, dem frequent flyer points
Edited by UNR33L
56 minutes ago, blah_blah said:
Effects nobody
yeah i know. maybe i should sue CBA, like that guy who sued Crown for making him spend a few million on a gambling binge.
Card minimum was $4k. i asked for over that and got almost 4x the card minimum.
1 hour ago, JAS-25T said:
if you go for other credit, including home loans it will reduce your serviceability significantly.
Significantly is a big call
Ill let Hamish answer this
But didn't effect me at all and i just refinanced last month
  • Like 1
26 minutes ago, JAS-25T said:
They look at the full amount of the CC being serviced at a fairly high rate, close to 20%.
at $27k that's $450 just in interest each month.
So even though the limit is unused they assume repayments are to be made as if it has been drawn in full?
Well that's intradasting
What difference does it make if you don't actually use the limit?
Effects nobody
How do you pay extra interest to a bank if you haven't drawn the funds?
When applying for home loan your credit card limit is used against you in your borrowing power. The smaller the limit the more you can mortgage
So like... nowhere? (i just got an amex so I could use apple-pay and literally no one accepts it lol)
that just means you could afford it pal - ferrari
Any line of credit facilities are considered as if fully drawn, as you have the ability to do so without notice
I use my Amex 95% of the time....don't know where you're trying to shop but they probably serve coffee in a f**kin jar so wouldn't expect much from them..
As for credit card limits, it's really not an issue. If you're going for a loan you decrease the limit, get the loan, increase the limit again. The cba lender chick did it for me off her own back... Literally zero effort on my part. And I mean literally in the true sense of the word, not literally in the way every f**king idiot uses it these days
  • Like 2
BP fuel, Coles, Maccas just to name a few..
f**king LOL almost spat my coffee out to that first line
I find that it's accepted probably half the time I would like to use it... and even when it's available it's often not contactless.
getting a card out of my wallet is so 2015
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
