1 hour ago, blah_blah said:
Those who have brought aftermarket diff's Kaaz or Nismo
Where did you guys end up sourcing it from?
Nismo cheapest i can find is RHDjapan
Kaaz only from MD spares in Aus
weld the f**k out of it
Moh how long you going to USA for?
have you got a "Don't shoot I'm not black" tshirt
if there on the 9th Nov remember to have a oh crap Trump got in/didn't get in anti riot kit.
If I was a visitor there not sure which would be worse, trump supporters celebrating or protesting..either thing will involve guns.
I got my KAAZ centre from eBay
Such a beautifully predictable diff
Speaking of, aside from the loud road noise, I can't speak highly enough of the Federal RS-RRs as a bargain tyre. They are definitely soft; already got some burnt rubber near the edge of the side walls after some spirited laps through the mountains, but the grip on hand from a $180 tyre even on the smaller 245 tread is sensational. Left a knee down 600cc bike for dead on Sat...he wasn't slow! Really like to try these at the track.
  • Like 1
Talking to richo he agreed...untill you some proper heat cycles then they go off, just like the old ones.
SO great for street as they don't get to track temps. but not so good.
what they have been testing out on the BMW was the nagkang NS-2R and having great results at 140 a tyre, (think R888 quality not A050)
http://nankangtyres.com.au/tyre/ns-2r/
going to grab some when back on track.
Might try them next, particularly if they are quieter than the Federals, but I think at beginner speeds/laps I wouldn't be unhappy if these only lasted me a couple of track days and 5000-10,000km of street driving. We shall see.
Also loving my Shockworks coilovers, which in spite of feeling firmer, dispense bumps in the road much more predictably than my previous setup when pushing it.
$1.4k off ebay for a Kaaz
$1.1k for a nismo from japan + shipping + GST
I remember Kaaz used to be a fair bit cheaper
I paid about 950 from memory, perhaps 6 years ago? That was a trade price, from Jackie Chan / CP motor or whatever, and for the 1.5 way.
I've heard nismo and KAAZ are much the same centre. Perhaps as KAAZ built a name for themselves, like Kumho tyres they got more expensive?
17 minutes ago, admS15 said:
Try Jesse Streeter
Yeah about $1.3k through Jesse for a Nismo
You work for a place that rebuilds stuff like diffs right? Same same to repair a kaaz and nismo? Heard sourcing and replacing parts for Kaaz would be alot easier
ill be leaving the US on the 10th lol
Used to...we didn't do many rebuilds of clutch pack LSDs, just your average Commy/Falcon shim job. If you're talking clutch packs then the KAAZ should be cheaper to source parts for. Again, they may use the same parts as the Nismo? They last a long time though. No rebuild for me yet; I do change the diff oil often though (every 10,000km or so).
  • Like 1
24 minutes ago, UNR33L said:
nah m8 ford 9inch diff m8
Used to do a lot of these conversions
We had bolt on solutions at one stage, axles disc brakes calipers and all. Just unbolt the rear and install.
From what I've seen it's the "tolerant" left more inclined to be violent in their protesting
What a load of "poor-me" conservative facebook comment section horse shit.
Let me guess, the left media is opressing you too by holding back the silent majority?
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
