2 minutes ago, Kinkstaah said:
Top is the 3582. This is from a couple of years ago now, the most updated graph is in the Dyno section. (and is 'better')
Point really was explaining why I went up a turbo size was logical at the time.
Since then yes, I'm happier to run less boost/bigger exhaust/better manifold/different exhaust which has all happened since then actually.
But my way of thinking (and Trents, and Scotty who was also there that day) was the standard motor has a rev limit of 7000-7500 functionally, and this thing is very upset at 6000, so it can't really be ideal. I didn't just change it because I have an insatiable lust for MORE POWERRRR for fake internet recognition.
I'd much rather run something less hard and utilize the rev range the motor has/should have. Just feels better than beating the daylights out of a turbo to within an inch of its life. (moreso, I have overspun one of the GTXs!) and short shifting it.
Just didn't seem like the best of plans.
You have added displacement from a stroker kit, this changes the dynamics and gives your engine a low-mid advantage over the standard engine - I would be taking advantage of this instead of worrying about the top end, where displacement means much less in turbo applications. As long as it makes the power you desire, who cares if you're shifting at less than 6000rpm?
Apparently Greg does.
Greg doesn't really, but that behaviour certainly wasn't seen in engines larger in capacity (like 3L 2JZ's).
There's also no actual advantage once you're moving if your powerband is from 3K to 6K vs 4K to 7K RPM. To a certain extent, you can just rev the smaller displacement more.
In any case, there was clearly something wrong, and I needed more flow out the turbine end or less restriction. That meant a 1.06 rear, or realistically a GT35 turbine with a .82. I did consider a GT3576R in .82 which would have been just fine, but the GTX3582 was
a) Cheaper (I got it for $1400 new) I could sell the near-new GTX3076R, so I lost nothing in the swap over. It was cheaper for me to go GTX3582 vs putting a 1.06 rear on the GTX3076R.
b) Easier, the GTX3582 is a proven product and definitely one of the 'best' turbos that garret made in the GTX range. The GTX3576 was more unknown, and more expensive, and made less power, and was a more expensive way of putting a 1.06 rear on the GTX3076R really.
Keep in mind 22psi, it's not like I was trying to max the thing out and make 550RWKW at 40psi that some people do with them.
There is method to the madness!
Less restriction I agree with, am all for the engine being able to breath and less stress on it and components, and if that makes more power up top then great - better to have and not need it...just feel like your setup is/was not reflecting what you desired in a vehicle. Turbos are always a compromise between lag and power; seems to me you're taking on unnecessary lag for a better top end that you can't/won't even use, when you could be looking at a wastegate or custom rear end solution to produce response without the detrimental restriction.
This top end large turbo stuff makes sense in race cars, like the 80s rally cars that ran GT35 sized turbos on 1.5 engines etc. Street driven, occasional track cars work better with small turbos driven harder IMO. Be faster in most places rather than one place. Tony will tell you how much this helps me with the rolling drags for instance. Subaru, Mitsi and Mercedes have embraced this on their 2 litre engines which see 14-18psi+ in standard form with their small turbos.
What manifold are you running again Greg?
This is all running on a flowed out manifold that Tao from hypergear made.
Before OH LOL STOCK MANIFOLD CAUSING PROBLEMS. I am able to put a 4psi spring in the wastegate and I get absolutely zero boost creep, it'll happily vent and run at 4psi all day at any load at any RPM. Plenty of others have gone tracking much harder than I have with gates off stock manifolds or turbo housings.
I'm still planning on changing the manifold anyway.
For comparison sake - tapers in the top end, well before 6000rpm (my rev limit is 7500), but it's more linear and plenty of area under the curve = huge midrange to work with
This is a 3071 equivalent turbo pushing only 15psi - rest goes out the large internal wastegate. With an extra 300cc, it's very odd that a 3076 shouldn't produce a similar curve for you - definite restriction but I don't think the turbo itself was the problem.
2 minutes ago, Count Grantleyish said:
I'm impressed it made that much power, especially with T3 flange actually.
Or has it been "converted" to T4 flange?
T3 Flange, and it was making that through an auto so... 460kw? Yes that's very high. I also thought that may have been a problem, but I never experienced any boost creep. Hence my test with 4psi.. which also does not creep. I guess the logic that the ports all have to converge in a flange of some sort is sound, though not as nice or as smooth as a T4 Twin scroll setup.
I entirely agree with this sentiment, but the GTX3582 did drive better than the GTX3076 did as well, better transient repsonse, just better everything really. The GT35 wheel felt a lot 'better' than the GT30 wheel ever did in the setup. Neither setup was laggy with the auto spooling it up and getting it all going. There almost no need to ever change gears out of 4th (same ratio as 5th in manual land). Just give it 40% throttle and let the auto take care of the rest. Had quite a few people drive it and comment on how it didn't even seem to matter what gear it was in when you're at a cruising speed driving along in the road.
Small turbos driven harder is good. 18psi is "harder" but that is not 35psi. I've never run more than like 22-25psi on my car, because I'm not chasing some record breaking theoretical dick measuring max, I just want what I've got to work pretty efficiently and work 'well' for what's in there.
186kph is about 6500rpm.
Perks of auto - are you going manual though?
I would like to, though I have no real "reason" to get rid of the auto which admittedly works pretty fkin well and refuses to die.
I would NOT recommend this turbo on a 2.5, especially not on a manual 2.5, and wouldn't even without a custom stall converter on an auto. it'd be fkin crap. No power till 5k and a 7k redline = shit life.
The reason I wanted a smaller turbo, that makes ~320-340 is that is close to the allowable max of a manual gearbox as well. It's a little bit over actually, but its not complete instant death to the gearbox...
I actually would prefer a 7163, but given that MAXES OUT HARD at about 320-330kw and there is danger of overspinning them... I'll go one size up and run it at 80%.
See? Logical!
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
