9 hours ago, emts said:
assuming it the owner of the Pizza shop he normally has his RR Phantom there of a night or occasionally his aventador.
Mustn't pay his employees penalty rates...
12 hours ago, emts said:
Race pace build with gt-ss's
was good old cylinder number 6 melted a hole right through
Hmmmmmm surely something like that might get picked up before it's too late?
Short on power or not driving same, check comp and see cyl 6 is way down? Cyl6 because of low oil pressure or heat or something?
one less person living off my taxes...nice.
Did you have income insurance? if so did they pay out? just curious how hard it is to claim on
which one you get?  School?
started shopping for car parts yet?
Didnt even bother applying for centrelink, cbf with that shit rather just get a job.
And nah didn't have income insurance, the school wanted an expert for entry level wages, this one is at another I.T MSP - New bike will be coming in a few months I reckon :)
Edited by UNR33L
They asset test you anyway. If you have any substantial savings they make you live off that for 10 weeks or so before they'll put you on centrelink.
Does income insurance cover you leaving your job?
not you quiting or taking a voluntary redundancy, but if your forced into redundancy, company goes out of business that sort of thing.
My company pays for us just to keep us feeling safe. so %75 salary for 6 months or so.
don't know anyone who claimed on it however as in our team any-one who has left went straight into a consulting partner
Yeah figured they would which is why i ddin't bother applying, not that i have heaps saved but yeh.
Doubt it, i'd say it'd only cover redundancy?
Yeah income protection not as useful as i originally thought when aigned up, but still got it. Comes out of my super at like $20 a week. Id say amust have for people with mortgage and family.
Not too sure on exact requirements for redundancy or company going under but mainly covers injury.
When i was still employed but small business didnt have much work, no coverage.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
