1 hour ago, joeyjoejoejuniorshabadoo said:
Added "senior" to my title today
A way of giving you a promotion without giving you one?
Did it at least come with a pay rise?
Congrats brah
11 minutes ago, Leroy Peterson said:
I hope to get Senior title when I hit 10 years in the industry... 2 or so years to go. Then hopefully people will take my resume seriously ffs
Just add it now anyway.
When I was 17 I was the product relocation specialist for the largest supermarket brand in Australiasia
The RB26 tax on that build was unreal. Two in a row asking for 28-30k for an engine.
Maybe I'll put 26 rocker covers on it and up the price by 15K. Throw in some free VCT or something.
Congrats brah
Nah, it's a proper gig. moving to Camberwell Business Banking Centre too.
They came to the table financially, but I took the job on the provision that I move upwards when the next opportunity is there so that's the real motivation
  • Like 1
I want to get out of technical work and go into an I.T PM role before becoming a 'senior' don't think I've got it in me to continue down the tech path forever.
No one wants to listen to a 27 y/o boss them around though, I still gotta do some courses too to get in the door
Just add it anyway, what's stopping you?
My boss, because he charges me out to my job title.
When I first started in small business I was barely 6 months out of my time, so added a junior title, boss said get rid of it or clients will think they should pay discounted for a "junior"
To start with you would look like a jackass who thinks they are better than their Peers.
Better to go to the boss direct discuss your reason for being promoted and if there things still to cover off build a plan to get there.
that said if your going to lie on your signature why stop at just Snr might as well go CTO or similar.
Be your own boss, grow some balls
23 minutes ago, Leroy Peterson said:
Lol
You have no idea.
Sorry to have misled you with the impression you were going to gain sound career advice from myself or VWL in general
  • Like 3
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
