I got nothing but praise for Internodes customer service and billing/sales. Now that i have an NBN box installed i would switch back to them in a heartbeat
Though guy at work is trying to convince me MyRepublic's $60 high speed NBn unlimited plan is the way to go
Search whirlpool for CVC for each isp. That's what you are paying for now as it's all running on the same infrastructure.
Car washing stuff. OMG got onto a telstra tech that know's what he's talking about :O
Tier 1 is offshore. Tier 2/3 are onshore to deal with any fall-outs/exceptions/complaints
In the case of billing disputes or customer complaints where you are ready to walk most banks/isp/telco's have a Business Saves team which are responsible for convincing potential leavers to stay. They usually have more authority to provide compensation/escalations. To get transferred through to them however requires you to trigger some keywords/questions to validate your intention to move.
2 hours ago, Odium said:
Pretty sure the G6E T has the same engine and gearbox, but no LSD and softer suspension?
2300kg is an impressive tow weight, compared to 1600 for most commodores unless you get a wagon and calais
Pretty much yeah just the diff.
I THINK even the suspension is the same.
The 6 speed auto is a great gearbox, and as you said has good towing weight.
Don't forget they all use 5x114.3 too so you can wack on some spare JDM wheels yo. if you ever need/want to.
How much you looking to spend? I'll keep my eye on the club fg group..
Edited by UNR33L
Chasing a Mk2 for ~$25-28... Specd up interior is a requirement now that I've looked into the differences you mentioned.
I'm alright with some mild mods as long as they're subtle and it comes with a RWC.
Yeh that'll get you a nice mark2, the touch screen is a nice touch, they have the projector style head lights too.
Must get leather though, as all the door trims etc look wayyy better.
Mark2 look alright in white, those are stock wheels too
Edited by UNR33L
  • Like 1
16 hours ago, Birds said:
Wicked keep it up
Your old pants must be huge on you
thanks bruh.
down to a size 36... used to be a 40-42, ive kept them though. chuck them on when im working on the car lol.
i couldnt even fit into slim cuts and down to an L work shirt...
belly and titty fats being fair stubborn though.
Do falcons without upgraded sound system still have room to install an aftermarket sub? Plenty of gear to fit falcons floating around. Im sure itd be cheaper than factory options, probably no difference if secondhand.
Got done speeding in the domain tunnel when it was at 60km/h. Cameras adjust with speed, eh? well there ya go. Gonna try for the good behavior letter and hope it lets me off. Haven't had an offense in around 3 years I think.
You broke the speed limit, why do you think you should get off
one of my employees got done for a high level drink driving offence in sydney on new years, plead guilty and lost his license for 12 months.
believing it only affects sydney, continued driving and got picked up in a set up, then got caught again the next day.
hes still driving... and reckons 12 months is too harsh.
well, wait till court day mate... i reckon hes gonna cop an extra year for the two unlicensed driving offenses as well.
I think the standard sound system doesn't have tweeter or sub grills in the pillars / parcel shelf, and also no amp.
Mines premium has the 2 front 2 back, sub in parcel shelf, amp, and 2 tweeters up front. I'm sure you could fit your own stuff but imo the premium sound is fine if you find the right car. Took me a while to find a GS fully optioned already at a showroom in black, finally found one and bought it
Cannot stress enough how bad the cloth interior vs leather looks though.
Simon, try find a cheap GS 5.0l? :P nothing good on carsales at the moment though
Edited by UNR33L
standard system sucks massivly, I've repalced them all with 6inch co axials in front and 6x9 at rear, much improved (not much space for a sub in the cabin...)
also added the aux connection as the radio in the BA has shocking reception, thus the external antenna in the FG
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
