Nope, I think like Dezz I bought them at the worst possible time.. In the last year hasn't hit green, could be worst, could have bought TV2..
Boral Limited is where it's at m8
I was gonna wait for this thing in a month and sell, regardless of the outcome I reckon
Edited by UNR33L
quick question for the finance/housing people here.
how hard is it to get a loan if you have had a bankruptcy?
some friends of Katie finished their insolvency period a couple years ago and are now building a new house.
would not have thought they would have got a loan??
They volunteered to do it as part of a Law Enforcement in Schools training thing, I guess the best way to stop people getting pepper sprayed in real life is make them see how much they hate pepper spray :P
The look of regret on their faces is immediate :D
That shit would suck
I remember years ago at Baysy maccas a fight breaking out and the cops unloading spray everywhere inside. Everyone had evacuated including staff but a mate and I were half way through meals so decided to stay and finish...few minutes later our eyes started to water. Kid who copped the brunt of it was reacting much the same way as them^
The SSD dock I bought came.. Got the SSD in there and plugged it into my old laptop...recognised it straight away, but its only showing up in the devices in the system tray, not as a hard drive in file explorer... Am I missing something? It says 'usb mass storage device' like I'd expect, but can't actually access it as a drive...
Open "Computer Management" and go to the Storage -> Disk Management section.
See if the drive appears there with the correct size, etc.
Whatever you do, don't Initialize Disk or Format it if requested to do so by this page.
I think your credit rating gets defaulted for like 5-10years? But that certainly doesn't stop people from getting loans during that period.... if you know what I mean.
I'm just trying to work out how they get offered 400Kish on low income with a bankrupcy
thought loans were getting harder not easier.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
