12 minutes ago, Kinkstaah said:
I always thought the lights were good enough right up until you posted that picture.
Thanks for that.
Lol really?
The butchered headlights from compliance is really bad.
Lighting is really poor at night. And on roads trips felt a bit dangerous without always using high beams
Compared to driving the wifes car with xennons its a massive difference
Just fit some 50w HIDs
Blind everyone else in your pursuit of visibility
Never had so many flashing lights from drivers in the other direction
Have to drive with high beams on because low beam is too bright
The number of people with unfocused headlights or driving with high beams on seems to increase every year. If I'm getting hit in the eyes sitting tall in the hilux, can't imagine what it's like in a low car.
Doesn't matter in the Gloria, tint is too dark.
16 hours ago, TiTAN said:
Maybe they just see the wheels as a disposable/wear item?
It would certainly speed up multi story car park navigation or lead to increased kerb crawling opportunities.
This.
I preferred fake rims as I never had to care.... ding one and pay $250 for a new one, or just roll with the scrapes.
Having real rims I was always too scared of carparks
15 hours ago, Birds said:
Melbourne has the worst multi storey carpark I've ever seen
Hamish will know which one I'm taking about
It's about 8 stories high and can only fit about 18 cars on each level. Thing is a fkin go kart track. You just about have to do 3 point turns to turn up and down its steep ass ramps, with your head out the window to make sure you won't clash with concrete walls covered in other people's bumper paint.
Which one? I am confuse
1 hour ago, blah_blah said:
Whos done projector xennon retrofits on their car?
Bout to do one on the R34
I had them done on the EVO, well, not me but the previous owner... I absolutley hated them at night as they were HELL directional and you couldn't see a f**king thing that wasn't straight in front of you. - simon will confirm i'm sure.
43 minutes ago, joeyjoejoejuniorshabadoo said:
This.
What brand components was the retro fit?
Big difference to installing a hid system to exisitng system and installing a proper retrofit kit
shit ones
In a lowered Skyline you get blinded by parkers let alone anything else
2 hours ago, joeyjoejoejuniorshabadoo said:
This.
Billboards carpark
He will.
Completely black off to the side... but anything that was straight ahead of you would be laser beamed... The majority of the light stayed down where it should, but some strayed up. Turned Eastlink Signs into Bright Neon Reflectors from about 2km away, i was always shocked to see how much light they were putting out.
3 minutes ago, Birds said:
When I turn on my HIDs people laugh at how bright they are, then 5 seconds later they finish warming up and the laughter turns to concern
images?q=tbn:ANd9GcSfyjK-AX2m2cWg9WRW-4B
  • Like 1
My mate's old 4wd had these huge spotlights and lightbars on the front, with a switch inside labeled "Zombie Lights".
Standing a few meters in front of it you could feel the heat radiating from it. Was afraid of starting bushfires ;)
Yet I was still more paranoid driving past police at night with slightly less than legal HID's
  • Like 1
I pulled up behind a copper at like 5am in the EVO... you could literally see the inside of his skull being fried in the rear-view mirror.
He was squinting like a real estate investor but still didn't pull me over
genuinely lol'd
  • Like 1
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
