35 minutes ago, Kinkstaah said:
Anyone know a decent auto elec that is mobile in Vic?
Not necessarily an "after hours cash only" style job, need a professional that can un-f**k a clusterf**k.
You and Pat
  • Like 1
I dont know any mobile auto elecs, no. Will be taking pulsar to a motorsport wiring place to do stuff from scratch, seems like lots of auto elecs dont like f**king around with others peoples messes.
Also lol @ comparable deductions to other sparkies.
Claiming unnecessary performance mods for your car on tax is immoral. Like claiming dog food for security purposes.
Good luck to you, but youll probably get found out eventually and get reamed like Gregs R34 at Racepace.
2 hours ago, dezz said:
If I'm gonna do it, should probably get it done before eofy.
Other thing to consider is warranty... Walkinshaw / harrop etc offer warranty, at a cost, haven't really looked into how it affects the manufacturer warranty if at all... But my mate recommended dynomotive or dpm, sounds like they offer more and better quality for less than walkinshaw etc...
Does their warranty cover your engine or just their component failing? Be surprised if any engine modification offered liability insurance against total engine failure given so many indirect variables can cause it.
Centrifugal chargers also have the tendency for an engine to not feel 'boosted' at all, a positive displacement charger you mostly feel down low, turbos give a big turbo kick we're all familar with
Centrifugal chargers just feel like a larger N/A engine, their power on a dyno is almost a completely straight 45 degree line. So you do get instant boost, but max boost is always at max engine RPM.
After installing turbos, my next car is going to be a supercharger setup.
Heat management > ALL.
A RB with a 300KW centrifugal charger instead of a Turbo would probably drive like a similarily powerful V8 N/A (like a LS1-2)
Except way less problems with heat, lines, plumbing, etc.
If I was adding F/I to a car which didn't ordinarily have F/I (like a S2000?) a centrifugal charger suddenly becomes really very viable.
I think there's a handful of people who have done supercharged RB's.... I don't think any of them recommended it.
Hell even the supercharged SR20 people usually go turbo afterwards. Same with F20 Honda motors
Engines too small.. by the time you add a charger you're making it struggle even more, say hello to your RB15 (1.5L, that's the joke)
Is there any point spending money on a EJ257? from my research looks like minimal gains (intake exhaust tune ~35whp?) Asking for... a friend.
Edited by UNR33L
Pls just stop
  • Like 1
Changing the forced induction method on a vehicle that came factory with FI is very silly
Superchargers have a constant lag of their own that is just negated by the power gains when they start making a little boost. You'll notice it on a smaller engine and fuel economy will suffer even if not giving it stick
If you want that supercharger whine just do a gilmer drive or smash your air con compressor with a hammer until it whines
E85
Should be first stop for any decent FI power gains. Improve performance absolutely everywhere!
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
