18 minutes ago, Leroy Peterson said:
What sort of issues do people have if plugs too cold? If I run 8's on the street... Would I be better off saving 8's for track days only?
Fouling and yes. BTW, please pay $400 to photobucket so they can show your images.
My plugs were just fouly (which is odd because we had them cleaned when my turbo went on.. maybe a month/1500kms ago), and previously were never that state. My specific plugs looked like this:
So there wasn't a great deal of room for anything when carbon gets involved. But yeah, they were a bit "Carbony" which is odd because E85 generates less carbon and 'fouling'.
But yeah, misfires at idle/very low load and misfires at 20psi, Carboning up, looking rather "tan" or a darker tan than mentioned made me think they were no longer the best option.
All hail BCPR7ES (I bought 18) :P
Crisitunity
There is a Melbourne 88E shareholder meet up tonight, you should go meet some of your new pals.
I picked up 80,000 shares this morning for cheap, so that's paid for by approx tax return.
Feeling even better about my 6.4c sell a few weeks ago now
Yeah good move.
See if it hits a new low tomorrow from pommy influence, but I'm just gonna wait it out. They still haven't used artificial lift yet... 11,000 ft is a long way.
Details? I did not know about it
Another 30,000 for me
https://hotcopper.com.au/threads/melbourne-88ers.3535713/#post-25763781
I picture it in my head a scene similar to ^ that, but I know it would be the complete opposite.
Traralgon Toyota don't carry stock for 2006-2011 Hilux front rotors. And takes them over a week to get stock from Melbourne.
It's probably the most common hilux model in gippsland and a consumable part. They stock the brake pads but "we don't replace brake pads unless the rotors are done at the same time". So why would you stock one and not the other??
I've been to obscure car club meets, motorcycle club meets, LANs with people only known through internet, and the Melbourne screening of The Red Pill...I've learned to expect absolutely anything and the term "all shapes and sizes".
When work throw out over 2 grand worth of old equipment doing a cleanup, I'll take that.. already sold it too, self bonus.
Also had what looked to be Joffa look at my car on Sunday to possibly buy :D
Edited by UNR33L
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
