54 minutes ago, UNR33L said:
Yep, car has to be able to tow my trailer and dirt bike to track days on the regular.
Also onto shitty dirt roads when I go to the bush, so AWD might be nice to have.
tl;dr Buy another R33 GTR with a tow bar addon
All rounder cars are shit, but a necessary evil for people with only one car space. Daily and weekender is the way to go if you got a choice.
4 minutes ago, dezz said:
Aren't simmons like the Australian volk? Thought they were pretty expensive, not that I've ever looked.. I don't mind the simple 5 spoke, but don't really want something you're likely to see on several cars the same model as your own
yeah not cheap.
but no better way to show your true 'stralyaness other than stralyan rims on your straylan muscle car.
MAAAte, anything else and your not fair dinkum
  • Like 1
stock are 10.5" wide??? where??
what model you got again?
all my googling showed 20x8.5 +35 front and 20x9.5 +42 rear will borderline not require a guard roll.
you want bawler status and uniqueness:
HRE FF15 in Tarmac-black http://www.hrewheels.com/wheels/hre-flowform/ff15
lol
They used to be, I think they used to be forged and better quality but now days cheaper due to cheaper manufacturing process I guess?
Don't do it, too many of them around definitely in the Ford FG community anyway, I'm sure Holden the same.
47 minutes ago, Leroy Peterson said:
5x120 pcd = BMW
So I'll find something good.
If going black on black wheels you may as well not have good wheels, won't see shit.
Black looks good in person bad on pictures.
Arguments on both sides, some would say no point having a cheap daily if that's what you spend most time in, obviously if you could have a baller daily and baller weekender that's different, I'm going down that path with motorbikes though, track bike and road bike, at least they're cheaper $.
41 minutes ago, dezz said:
Stock rears are 10.5" wide, could probably get some decent looking te37s on there....
I thought 9.5? Check out some of the Vertini, HRE, Niche etc , thewheeldeal website has some good options, I think eastcoast tyres also recently opened a shop in Bayswater (they are big in sydney for holden and ford ranger boys)
Edited by UNR33L
Mate rekins you can get more for less money at dpm and dynomotive, so I'll sus them if I do anything to it.. Probably gonna have to get something else now that I've got the dog, once he's full grown, or option 2 is lose the hard cover and he can go in the back
New M140i is ~60k, will go harder than wrx and isn't ricey. The new civic looks awful
What advantages does this have over say, a train, which I could also afford?
  • Like 2
Fewer smelly people in your immediate vicinity
Not none as you have children
  • Like 1
yeah just put him in the back, put mine in the back of the mrs yarris
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
