I drove a vn wagon that happened to have internationals on it for a while. Towed pretty good, but there was rub as the suspension squatted (pan hard bar pushing the axle sideways). Made an ok tow car with heaps of room for tools in the back.
Edit, forgot CSH.
3 hours ago, HEKT1K said:
see a lot of Maybachs out your way Birds?
Not as many since we signed that petition to stop them parading up and down our street so often
I think I might actually buy these wheels...
https://page.auctions.yahoo.co.jp/jp/auction/u160682457
1200x900-2017090300006.jpg&key=5dbb2312e62968a2317e1c29d2133da1a830ae0ed6939c1243aca19e02da458a
Edit, on second thought it's not that much more to buy brand new and customise. Plus jesse said too much risk for secondhand wheels that price.
When you're sick for a few days at the start of the week, get a medical certificate but the doctor puts the wrong dates on accidentally (forward a week).. give to my employer and they ask me to get it fixed to correct dates.. call Doctors office, wait 3 hours for a call back.. get told yes but I'll have to come and pick it up, finally convinced them to FAX it through.
At what point was me wasting time worth it?
/Friday Rant
Do they make you get a med cert? My workplace never bother with it
I always thought of them as pointless when they can be obtained so easily. My opinion is if you're well enough to get a med cert then you're probably well enough for work. If you're too sick to work, why make you do the unrestful thing and go out to get a med cert?
Because the doctor gets to bill Medicare for your visit to get a note to say you aren't well, the ones where you go into work and then go home because you aren't well and they still want the medical certificate are even more meaningful.
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
