7 hours ago, Birds said:
Just looked it up...does look nice and factory. Wonder if the LS upset the handling at all...apparently doesn't bother the RX7s too much. That's probably something I'd say excessive / tyre frying. Be happy with about 200rwkw in an MX5; would be plenty to have fun and keep it tractable on the street.
No, LS won't upset the handling since it's light being all aluminium motor.
Surely the standard 1.8 is alloy and half its size?
i was more talking OEM engines, not swaps.
if we swapping I'm sticking with a  426 hemi,
cos fck yeah
The LS works as it's compact and lightweight, also readily available for not a lot of $$$. why not an ls7 or lt4/lsa if you wanted to go nuts.
Leigh considered a Megane RS?
https://www.carsales.com.au/dealer/details/Renault-Megane-2016/OAG-AD-14835438
These things are seriously fun, well equipped and good handling cars for the money
  • Like 1
This.
On ‎9‎/‎15‎/‎2017 at 9:29 PM, joeyjoejoejuniorshabadoo said:
MX5's are freaking amazing when done well. I kinda want an SE
GF has the SE. Did the alpine road this weekend, made a 3 day-er of it.
Seriously fun. Has AD08R's and coilovers on it now, it's just such an active car when you drive it hard.
One day it'll have a tune and make ~180rkw and yeah I'll probably deliberately write my 34 off over a cliff and buy three of them.
  • Like 1
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
