Why is there Victoria Secrets in every Aus international airport?
I always wondered, then when Sydney was getting reamed by traffic control and every flight was delayed, people go to EVERY shop just for something to do. Then people buy stuff. I reckon those businesses only need maybe 4-5 disaster days a year to make their money
4 hours ago, TiTAN said:
That brings us neatly to a very important question, Why is there a Mercedes dealership at/just outside the Melbourne airport?
That's a excellent question.
I've no idea.
You may have just uncovered the reason why a form of transportation built around near perfect number crunching and mechanical reliability is less punctual than a bus.
Parking is $10 in Docklands and yep, free tram zone.
Am 16km in distance to city so unless I bring the Ebike into the office and charge it at my desk.... it's not possible?
They're pretty pricey those Ebikes! Might as well get a motorcycle, plus I've always wanted one and seems like an extra excuse to get one me thinks.
Quick question for everyone, how does a deaf person know when to stop wiping their rear end after a poop???
"Normal" people have five senses right?
When one lose a sense and the remaining senses are heightened (not sure if it's right word).
For example, me - I'm deaf as pole as y'all know, i go to the toilets and do my business and when it's time to wipe, I go by feeling between my butts with toilet paper of course.
Also you can judge by looks if you're flexible like pole dancers - that being said I'm sure they don't do that way.
Or you could heed Birds advice and do 15 wipe system.
Please try these and report back I'm sure we all would love to know.
On the subject of e-bikes.
Surely they're expensive as everyone first looked, although there's a couple of benefits - no licence and registration is needed until the government decides it is needed which won't happen I reckon as it's still a "bicycle"
On 10/14/2017 at 6:10 PM, joeyjoejoejuniorshabadoo said:
Literally the dumbest thing I have read in 2017
Welcome to my workplace on Fridays, I'll see what other knowledge I can share with you guys this Friday.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
