18 hours ago, HEKT1K said:
Good stuff Leigh, is it quick?
Thanks mate, yeah it's nice and zippy. I kind of like how it has the 90s turbo car characteristics (little bit of lag then good power throughout the revs) paired with the awesome tech and gadgets. Sticks to the road well and can confidently turn out of corners full throttle, wouldn't dare to in the GS.
Took the STI up mount dandenong last night, the grip is unreal, even if I could grip on the GS because the front seats were like couches you just end up sliding out the window anyway.
Love how the new cars have the turning headlights where you're turning into and the automatic high beam turn-off when a car comes up or the other way, makes the hills very good fun :D
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
