88E touches 2 cents. Are we seeing early/slow start to ramp up or just some recovery?
Good start to my hypothesis about it being a guaranteed win for the 1.8 cent buyer
Updated all my apps for the first time in many months. SAU app takes 3mins to update Participated thread list and fb messenger app struggles to show gifs.
Never updating social apps again.
Bitcoin gonna break AUD10,000 this week.
If we convert those member join dates into prison sentences, Ric and I have done time for perpendicular vehicular homicide, Hamish is in for manslaughter and Patrick is a pedophile
  • Like 2
10 hours ago, Leroy Peterson said:
Will spend my bitcoins on alt coins before November 16th (the split). Then try and convert back to coins when it dips. See if I can pull it off.
split cancelled :( price hit $10kAUD then retreated. other coins going up in price. oh well.
On 11/6/2017 at 3:02 PM, UNR33L said:
Stock trading guys, keep eye out for this:
http://www.afr.com/business/health/biotechnology/telix-pharmaceuticals-snares-big-backers-20170915-gyiccx
http://www.bioworld.com/content/aussie-radiopharma-firm-telix-opens-largest-biotech-ipo-asx-csl-0
The Mrs works for their partnering companies and it seems the directors are investing BIG money before it goes public.. might be a good train to jump on board. I've got no idea as haven't looked into it enough but thought i'd mention it.
https://hotcopper.com.au/asx/tlx/
They're investing big because big investment groups have jumped on board. Making it public they get a huge sum of cash. I'm not familiar with what usually happens with a new IPO starts. Will keep an eye on it though.
As of this morning I won some Vertcoin and Ripple coins. the system seems simple enough. The system also seems very different from what the purpose of the currencies actually are! But open market is open market... just we all buying coins with no actual purpose other than to trade. At the moment its like a self-fulfilling prophecy.
What disturbs me about Bitcoin is how fast it's growing and how easily it could crash, all being hedged on future adoption
It seems to benefit a great deal from original and the best / household name syndrome like Google
But also seems to be the worlds biggest upramp
Good luck picking when to get off that train
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
