4 hours ago, UNR33L said:
Yeah it's good, handles crazy good and brakes are awesome.
It's cool having a new car with heaps of modern features with an old school feeling turbocharged engine & manual gearbox.
The turbo lag and when it hits makes it feel faster than what it is, which in a way is good for the street. Once I'm nearing the end of warranty will do some mods surely, but for now happy with how it is, maybe just get a catback exhaust soon.
160awkw? not sure :D
Just mod it already, no need for warranty in one of these subies.
They're pretty reliable.
1 hour ago, Leroy Peterson said:
All good. I bought what I needed for $11.Still got a gremlin where with one of the rear parkers plugged in, it prevents the brake light on the other tail light from working... :confused: I've got a homemade CAD wiring diagram from online, but doesn't really help narrow things down.
/moneylinesaustralia
My $400USD venture into various crypto is now worth $570USD in under a month. Take that bank interest rates!
It's a bit confusing where values can be estimated/defined to USD, or altcoins against Bitcoin or Ethereum. So with bitcoin rising so fast, it looks like the altcoins are dropping, but against the USD they're increasing too.
What else are you on?
I’ve doubled in probably 7-8 weeks
I've heard mixed reviews of the engine reliability, not as bad as the Focus RS headgaskets though :O
It'll be catback first as no tune required then down pipe intake tune once I've saved enough side cash to help fund a engine rebuild if that happens :P
not much.
0.6 Ethereum, 150 Ripple, 30 Vertcoins. Traded out of bitcoin. gonna wait a bit. Gonna buy into ethereum more soon, then head into Substratum, Neo and Golem. ambitious ideas, but meh. who knows.
6 hours ago, Leroy Peterson said:
not much.
Are you just naming people from the Matrix?
  • Like 2
  • Haha 1
not a bad idea actually...
Apoc, Switch, Oracle, Trinity, Cypher, Dozer.
Very cyberpunk. Much anarchy. Such rebellious.
So some amateur car photographer posted a photo of the gloria and put it on instagram 6 months ago, mate tagged me in it, nek minnit she inviting me to a "secret cruise" in 2 weeks in Craigieburn. I cant see the facebook event to suss out who is going, but is this how kids do car meets these days? invite only. I mean, I am VIP, but driving through northern suburbs with P platers is not my idea of a Sunday arvo well spent.
Edit: think ill buy this and put it on my fridge
https://www.ebay.com.au/itm/GARY-OLDMAN-DRACULA-BUST-LIFE-SIZE-REPLICA-PROP-GLASS-EYES-FRANCIS-FORD-COPPOLA/263367932915?hash=item3d51f3bbf3:g:XmAAAOSwWHBaHY20
Yes, everyone is a bunch of invite only elitist flogs who are scared to have their idea of "this is a nice car" challenged.
I now have cancer from reading about "secret cruises" in Craigieburn for VIP cars.
i think ill be the only VIP one there. im assuming the rest will be hondas and 180's
You can attend those smashed gearbox or beaten by Birds meets
The "I stripped first when I launched it" cruises? followed closely by the "I got a built gearbox and a tough clutch after stripping first so I blew up the diff when I launched it" cruise.
  • Like 1
I miss getting those TUFF CARS ONLY sms's [emoji20] my STI isn't TUFF enough :'( or have 370rwkw
That's so f**king pathetically bogan I actually feel embarrassed for you
It was pretty funny. I went once and it turned into dandenong bypass runs with a lot of VL turbos uleh
  • Like 1
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
