15 minutes ago, dezz said:
Ran over something, bent k frame bent transmission bracket, dented exhaust ripped the heat shield, slight gouge in the rear bar and probably broke some clips on the rear bar as it came out the back.. They said they were gonna fix it.. Few weeks later when it was supposed to be ready I get a call saying it damaged the floor and might be written off, 2 weeks after that it was gonna be repaired, another week or 2 later and it was written off... Damaged transmission tunnel etc etc
that is shithouse treatment.
just curious due to my Facebook stream of late, suncorp group insurance, ie AAMI/Shannons?
Racv.. Dealing with the call centre wasn't too bad, think it was more the assesor side of things is a joke. First off it was 'the assessor is on annual leave' like I give a f**k, get another one.
So from what I've pieced together now, initial assessor saw it after probably 2 weeks of sitting at their preferred repair centre, maybe not his fault claims hadn't told him it's there etc.. He was the one that said it might be a write off.. Then I think he went on leave, I told them that's not my problem get someone else on it.. That new assessor said it'd be repaired, which I wasn't happy about.. Waited for his call for 2 weeks, called racv and repair centre a few times, who both said we're waiting for the assessor.. Told them not good enough escalated etc etc.. Then yesterday was on hold for 20 minutes (to be fair pretty much the only time I'd really been on hold) got disconnected at 20 minutes, was going to call back and lose my shit, 5 seconds later assessor calls and says it's a write off.
Went to pick up my belongings that afternoon, and repair centre receptionist and guy managing my job both had no idea it'd been declared a loss as the assesor hadn't called yet, and they both made comments that lead me to believe he's pretty useless at calling people/customers back
Policy is new for old, but given they're out of production I don't think they'll be able to replace it.. Sort of suits me anyway. I liked the car, but don't really need a Ute anymore anyway.. Hopefully get the cash, buy a half decent ~10k run around to replace the current excel run around until I decide what I wanna buy...
4 hours ago, UNR33L said:
Had to do some work in the city yesterday, got back to the car at 3:35pm to find it towed and could see it down the road.. RIP $405 (Glad it was the work car and not my STI at least)
Expensive 5 minutes (turned to clearway at 3:30pm)
Well you know old mate was just sitting there with tow hook in hand waiting for 3:31 to hitch
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
