34 minutes ago, Leroy Peterson said:
So what's this about manual boost control vs boost tee? Considering reducing the richness of the Gloria... (by adding boost)
Knowing Nissan ECU's, it'll compensate for the increase in boost by throwing even more fuel in. Are there tunable options for the gloria? Nistune / PowerFC etc?
Boost tee / bleed valve is a manual boost controller, just a very simple/cheap one shaped like a T. You used to be able to get one by TurboTech(?) for $25 that would allow a couple extra PSI on a stock ecu vehicle and hold it very well. Bargain performance upgrade on most turbo imports from the 90s.
Until you hit rich and retard and then drive along like you've lost a few cylinders ?
I notice the bargain 32R for sale thread disappeared from the classified section...guessing the new owner wants to resell it without people knowing what it originally went for ?
Yeah youre probably right :(
Piggyback or full race car standalone with 90% of electrics not working seem to be the two options haha. Like M35, im curious at the locally made M35 modded ECUs, but dont seem to hear much about development anymore. Scotty gone AWOL from sau too
Yeah youre probably right default_sad.png&key=60edf0cfeb1b5687d093da59e19dcb4bc4ca5078c255acb1c3a47ac6adc5cc5e
If i did try a boost tee, i would put it on a dyno probably with cms. If he cant get it going well, maybe his russian contacts can develop something. They managed to make tunes for the latest Nissan cube, which was supposed to be untunable
An guy put a 3000hp billet water jacketed funny car setup in a 57 wagon of some sort and took that to it, they would pull the belt off the Supercharger and tie a breaker bar on the snout to stop it turning, remove the manifolds blast plate and install a throttle body there for a 2nd ecu to run the car on the street. They had some issues with it though.
https://www.autotrader.com/cars-for-sale/vehicledetails.xhtml?listingId=487434773
Now THATs an investment. Signed by Pol Wolker himself. Owned by Frankie Muniz apparently....
It's actually a pretty cool looking car, if it had smaller wheels and more low
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
