Thanks, I guess there is no need for the extra revs if that's the power goal.
What head work would you suggest?
Just trying to wrap my head around this - appreciate your replies
head work depends on your budget. Commonly ppl go port & polish.
My head built by Jhh Racing - CNC ported, supertech bronze valve guides, valves & dual springs, ferrea titanium retainers
Hks 272 cams and tomei cam gears... There's a lot more involved but that's just the components
  • Like 3
Out of interest what are your goals and what head work is needed to achieve it?
My goal was to be able to rev as its built for a drag power band, so this head is built to rev till 10,000rpm on my bottom end.
This same combo has revved to 11,000rpm with a lighter built bottom end.
Edited by QUP29
  • Like 1
It's been CNC machined ported for maximum flow. I don't know how much came out as its a Jhh racing spec, secret squirrel stuff also forgot its 1mm oversized as well so yes they did do valve work!
Edited by QUP29
  • Like 4
  • 1 year later...
Don't know if anyone is still interested but here is my real world experience. Own an R32. Made close to 400 atw. With bolt ons. Never did cams though. Was happy till a minor engine issue. Decided to rebuild. Didn't know if I wanted a 2.6 or a 2.8. Walked into a workshop and got to go for a ride in 2 gtrs. Both were single turbo cars 600hp 2.6 and a 740ish hp 2.8. Both drove better than my low mount twin setup. Why? They were better built and better equipped and better setup cars. Everything was matching. Either one could be driven daily. A well built, well setup car will be most fun to drive. Find a good shop. Get good parts. Take your time. If the opportunity is there. Drive different setups. I was sure I knew what I wanted. After just two drives, my plan turned on its head. There are so many videos of cars. Every combo you could think of. Nothing worse then redoing something.
  • Like 2
So what did you end up doing George?
A high compression ratio, forget, worked 2630 with a gtx4294r on the side sculling e85 through id2000s and 3x044 pumps.
Our first plan was a 26 with twin 2860-5 then we decided to go for 6466. After pooping my pants in an rb28, plan changed again. By luck a few parts for a 2630 turned up along with a turbo kit and here we are.
But I will never forget the difference between my car originally and the 2 gtrs in the shop. They were so well sorted. No flat power spots. Everything just worked.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
