The reason I'm so interested in the GXi is because I'm thinking about getting one as my first car, possibly to swap an SR20 in. And I can't get a GTS-T because my parents won't let me get a fast car (Craig, the ER34 I was talking to you about earlier was for my dad, who is looking to import one ;) ).
i thought you were building a game with it
The reason we want info about this is because we want to include a base model car as part of a game mod.
same with the rs4, er43 hr34... all the others you asked about.
its ok man im just busting your balls.
in all seriousness while your on your ps just drive a hatch back or camry or whatever, no need to pay big money for a shit car that looks like the fast cars.
just save your money for a good car when your licenced to buy one
EVERYONE will say they wished they did that.
  • Like 2
We are building a game mod with the FR32.. we just can't give you much info about it because it's still very early in development :V
Thanks for your advice, I truly appreciate it ;) I'll drive my dad's Avalon on my P's then ;) But, in the future, if a FR32 comes for sale for a cheap price, should I think about buying it and swapping an SR20 in?
Edited by linuxfanatic
As I believe no importer will ever import the FR32, ask yourself, is it worth...
1. Spend money purchasing the FR32 from Japan
2. Spend the money shipping it to Australia
3. Spend the money putting it through compliance
4. Spend the money registering
5. Spend the money buying the SR20 / gearbox / diff / brakes
6. Spend the money fitting the SR20 / gearbox / diff / brakes
7. Spend the money engineering your now modified FR32
8. Spend the money insuring your now modified FR32
If you answered yes to all these questions and the gumbyment changes the rules to allow you to import a FR32, then draw up a plan on how to make it happen and then make it happen.
Personally, to me it makes much more sense to buy a R32 rolling shell that's already here in Australia and fit the engine / gearbox / whatever else it takes to have a working car if I really wanted a SR20 powered R32
  • Like 1
You're right. it's a shit idea. Could an admin please delete this thread?
  • Like 1
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
