Up for sale is my r32 gtr ( r32,4 gtr ) needs some love and attention:
the fibre glass wide body kit has stress cracks in some spots. will be sold with space saver wheels. will need to be towed.
car is also runing stock ecu ( it will start,but its rough due to not liking having no afm and running 800cc injectors) for the time being while the vipec ecu gets checked over as car wouldnt start with it. possible damage to the board from hooking up battery wrong way,
engine possibly needs a new head gasket and/or valves cleaned for sitting for a long time. has low compression on 2 of the cylinders due most likely to those reasons.
as for the good bits, Interior is in good condition,shouldn't take much to get it going.
Would suit someone who knows what they're doing or has a budget to get it running and looking good.
will look awesome with some TLC
Also just put in new NGK BCPR7ES spark plugs, new Optima Yellow D51R-T1 battery and a new POD filter.
probably alot of other mods i don't know about
would make an awesome track/drift car
car is full of potential in the right hands. my knowledge of cars was my let down but someone with more knowledge could make this car shine and become a beast of a GTR
Car has 117,502 kms . car has no been driven in a few years
Engine:
RB26
T04R Single Turbo kit
Stainless Manifold,
60mm Tial Wastegate
Tomei 260 Poncams
Tomei adjustable cam gears
Sard 800cc Injectors
Sard 280ltr Fuel Pump.
Gates timing belt.
R33 oil pump
Braided fuel lines.
Management:
Vipec ECU
as well as stock R32 ECU
Suspension:
Tein Mono-flex fully adjustable coilovers
Cusco rear strut brace
Driveline:
Stock 5 speed
Exedy triple plate clutch
Nismo short shifter
Brakes:
R33 GTR Brembos calipers all round.
DBA slotted rotors.
R33 GTR ABS unit.
Wheels:
space saver wheels (lol)
Interior:
Recaro SR reclinable drivers seat.
Jaycar speakers all round
Nismo 260km Cluster
2/4wd Switch.
Turbo timer
Viper Alarm
EXHAUST:
4" Veilside exhaust from Turbo back. With 2 centre mufflers (quiet)
Exterior:
Customised Full genuine Bee-R (B324r) Widebodykit with R34 gtr front end.
R34 Xenon headlights
Sparco alloy fuel cap.
post-14097-0-11352500-1446196425_thumb.jpgpost-14097-0-48395100-1446196541_thumb.jpgpost-14097-0-18371700-1446196551_thumb.jpgpost-14097-0-63155500-1446196560_thumb.jpgpost-14097-0-07759100-1446196592_thumb.jpgpost-14097-0-54672600-1446196601_thumb.jpg
what the car used to look like before previous owner painted Matte Black
$8,000 ONO
Edited by deprived777
https://www.sau.com.au/forums/topic/460690-r324-gtr-victoria/
PRICE DROP: $7,000 dropping price due to realising car will need some money put in it to get it perfect. if someone parted this out they would quite easily make profit. i just don't have the time,knowledge or patience to do it myself. Or invest time and money into it and have an awesome looking car that will turn heads. i've never seen another car like this on the roads personally
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
