GUYS!!!!!
I NEVER SAID THERE WAS RUST....
The car immaculate inside and out
Immaculate underneath (absolutely no rust)
only one australian owner since landed here in 2005
engine is completely unmolested
factory new paint...
one of a kind and rare to find
The way your thread reads there^
Sounds like you still have it and the 6th of December is hardly ages ago.
Also even if by slight chance you did get it repaired it would be nice to mention that in your ad to save someone else making the same mistakes you did.
Wouldn't it be a good idea if dpham closed all the for sale threads he has open, restart a new one with all the correct details for said car for sale, post pictures of said car in current condition proving that there either is rust or no rust and go from there? :miner:
GUYS!!!!!
Only one owner since 2005...but you bought it a few weeks ago?
Please stop the chat in here guys.
Ok pranky.
You heard the man - pull back, troops!
But...seller is tryin to pull a big dodgy here; the only reason we're mob justicing him.
  • Like 2
  • 4 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
