Circuit Time Update:
Circuit Name: Calder
Lap time: 1.06.35
Circuit Name: Sandown
Lap time: 1.23.27
Circuit Name: Phillip Island (need another go at this with healthy car :nyaanyaa:
Lap time: 1.57.16
Circuit Name: Winton
Lap Time: 1.38.75
Regards
Andrew
Car: R32 Gtst
Modifications: PowerFC, HKS 2530 Turbo, Injectors, Exhaust, FMIC
Engine: RB20DET
Power: ~170rwkw @ 0.9 bar
Suspension: Whiteline Sway bars & front strut brace.....rest stock
Tyres: some Nankangs
Brakes: Front - DBA 4000 Rotors/ultimate pads Rear - Stock Rotors/ultimate pads
Body weight: normal r32
Oran Park GP - 1.34.12
Car: R32 Gtst
Engine: RB20DET
Suspension: Whiteline Sway bars / Whiteline Springs/ Bilstein Shocks
Wakefield Park - 1.17.299
i'm really happy with my times so far
Car: R33 Gtst sedan
Modifications: 3" Cat back, 100mm thick SMIC, Cusco 1-way diff
Power: ~165rwkw
Suspension: SK's Whiteline Sway bars, Springs & Bilstein shocks, Cusco Caster rods, rear camber arm and tension rod, Nismo front strut brace and brake cylinder stopper
Tyres: Dunlop DO2G 235/45 R17
Brakes: Front - DBA 4000 Rotors/Hawke pads Rear - Stock Rotors/Hawke pads
Body weight: normal r33
Queensland Raceway Times
Sprint Track: 1:03.58
Clubman Track: 1:06.56
Sportsman Track: 1:04.84
National Track: 1:30.15
  • 3 weeks later...
SAU Nickname: DJR81
Car Make and Model: R32 GT-R
Circuit Name: Wanneroo - Long Circuit
Lap time: 66.73
Modifications
Engine: Fully sik Turbosmart bleed valve + an aftermarket exhaust.
Power: 305rwhp
Tyres: RE55's
Brakes: Stock
Body weight: About 1600kg with my lard arse in it.
Car: 180sx
Modifications: Diff., turbo, injectors, thermo's, aluminium radiator, Z32 blah blah blah
Power: 200rwkw at track
Suspension: Camber arms, castor rods, Tein super streets, strut braces, lower arm brace
Tyres: RE55s
Brakes: R32 GTS-T coversion, Project mu SCR discs, Project Mu pads, braided lines
Times:
Circuit name: Winton
Lap Time: 1:39.863
Lap Time: 1:28.32
New Time: 1:25.091
Circuit Name: Morwell
Lap Time: 59.21
Car: R34 GTX-T sedan Tiptronic
Modifications: 3" CES Exhuast with Split Dump
Power: ~176rwkw
Suspension: Whiteline Springs & Bilstein shocks, Whiteline Front and Rear Camber Kit, Whiteline Castor Kit, Whiteline Pineapples.
Tyres: Bridgestone Potenza GIII 225/45 R17
Brakes: Front - Stock Rotors All Round, Hawke HP Plus pads all round
Body weight: Stock R34GTX-T
Sprint Track: 1:03.22
Clubman Track: 1:05.73
Sportsman Track: 1:04.04
National Track: 1:31.56
SAU Nickname: Chris260
Car Make and Model: R32 GTR
Circuit Name: Wanneroo - Long Track
Lap time: 1:06.20
Modifications
Engine: Power FC Dejetro, 1 Bar Boost
Power: 356 AFW
Suspension: Tein Coilovers
Tyres: RE55s
Brakes: Standard
Body weight: 1543kg (Without Driver)
  • 3 weeks later...
Car Make and Model: 89 300zx
Circuit Name: Eastern Creek
Lap time: 1.49.1
Modifications
Engine: ?
Power: ?
Suspension: King springs and Bilsteins
Tyres: DJ01 front, Falken RSV04 rear
Brakes: stock
Body weight: stock
Car Make and Model: 01 Holden SS ute
Circuit Name: Oran Park GP
Lap time: 1.25.6
Modifications
Engine: Stock
Power: Stock
Suspension: Stock
Tyres: Bridgestone RE540S front, Dunlop DJ01 rear
Brakes: stock
Body weight: stock
Lap time: 1.06.35
Lap time: 1.23.27
Circuit Name: Phillip Island (need another go at this with healthy car :(
Lap time: 1.57.16
Lap Time: 1.38.75
Regards
Andrew
New P.I. time = 1.52.5
Regards
Andrew :P
Queensland Raceway
Circuit Distance - 3.121kms
National
1. jlnewton , R33 GTR - 1:03.15sec
2. stealth , R33 GTST - 1:03.33sec
3. gtrvspec95, R33 GTR - 1:05.56sec
4. predator , R31 4dr - 1:18.55sec
5.
6.
7.
8.
9.
10.
You might want to put my time in Sprint ...
As I doubt I have the skills to rip out a 1.05 on the National circuit on my first time out :lol:
I'll try if I get the car ready for the 16th this month thou
Regards
Andrew :laugh:
wow that's a massive time drop!
well done, what were u doing differently? oops I just read the car wasn't as healthy when the 1.57 was done!
still a top effort!
Car Make and Model: R33 Skyline S2
Circuit Name: Queensland Raceway
Lap time: Sprint 57.25, National 1:19.70
Modifications
Engine: RB25/30
Power: not enough
Suspension: SK's stuff :)
Tyres: Dunlop slicks
Brakes: Usual 4 spotters
Body weight: about 1400kg with driver and fuel.
Car Make and Model: R32 GTS-t Type M
Lap time: Sprint 1.03.78, Sportsman 1:03.39
Modifications
Engine: RB20
Power: 204rwhp
Tyres: RE55s
Brakes: Standard with Ferodo DS2500/Bendix Ultimate combo
Body weight: at a guess, approx 1350kg with driver and fuel.
  • 3 weeks later...
SAU Nickname: Blue 32
Circuit Name: Mallala
Lap time: 1:22
Modifications
Engine: r34 RB26DETT
Power: 330kw at the wheels
Suspension: Coilovers / Tomei Hicas lock kit / adjustable upper control arms frt and rear / adjustable castor rod / tomei body bracing
Tyres: Advan V103 street rubber
Brakes: AP 6 pot 330mm frt / stock with endless pads rear / braided lines
Body weight: stock
Heres some GTR times from a recent track day around the short curcuit at Barbegello
Chris260
Chris Reynolds
Skyline R32 GTR
0:57.0350*
356awHP
RE55's
djr81
Richard Miller
Skyline R32 GTR
0:57.7766
305rwHP
RE55's(?)
PSI_GTSII
Lindsay Rea
Skyline R32 GTR
0:58.9880
315rwHP
Federal 595RS
Topaz
Tom Passey
Skyline R32 GTR
1:02.3269
321rwHP
Street Tyres
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
    • Been a busy but productive day. Axle and hubs acquired. All fitted up after a bit of modifying. Need to sort out wider mudguards and running light reflector covers but other than that the trailer is gooood to go !!
    • Selling a SMIC for a Nissan Stagea C34 Series 2 and the pipe from the intercooler to inlet. (I believe it is the same R34 GTT, please correct me if I'm wrong) Price: $50? I dont have a photo of the big black pipe that goes from SMIC outlet to throttle body.
    • So the original radiator is leaking now. Looking at getting a fully aluminium one next. Am I correct in saying that the Series 2 Auto Stageas have a separate trans cooler from factory (located in between the rad and intercooler in my previous post/message).   Currently looking at Fenix $460, Blitz $700, GReddy $800, and KoyoRad $740. What are everyones thought on Fenix ( ive read a few comments saying theyre cheap Chinese rebrands etc and how their build quality is... well.. chinese...)  compared to the others? Worth the extra couple hundies?
