Hi All,
Got my V36 dyno-tuned at CRD yesterday.
Combined with just putting some dry type cold air intakes on it (no other mods), it has tweaked the performance of the car to how I would like it to be with minimal cost.
It removes the throttle lag you get standard with this car and it feels more like it launches more. It has a 'Raspy' racing kind of sound now through all gears.
The dyno print out shows about a 10% gain in power and torque and increased top speed.
It has also made the paddle changes more punchy.
I recommend it as the first thing to do to anyone who has a V36 stock standard as it changes the whole feel of the car.
Cheers.
Did they reflash using ECUtek like mine was? Post up your dyno graphs like I did in 2014. I'd like to compare.
Have you got a link to your graphs ? I would be keen to have a look thanks
OK did sound like a cool story. While we are judging some of you need a hug.
Got the intakes off AsM. 'Satisfaction' Cold Air Intake Systems. You can see on You Tube. The intakes changed the sound of the car.
Anyway that's all I wanted to do to my car so I'm happy with it. They probably flashed it with UPREV and told me it was a dyno-tune, but that's the art of being a mechanic.
For me I'm loving the torque, throttle response and power off the mark, particularly in paddle shift mode as I have an SP.
Attached is the dyno-graph.
I had the "03" 350GT Skyline and put the APS Twin Turbo System on it, only took it to 253awkw I asked for a mild tune, the turbos kicked in early , it was a fun car to drive. Added attachment, just loved that blue
While I was getting some work done on my R34 Jim mentioned something about a different chip for the 350GT that helped maintain the tune or something like that and was a good addition, maybe they have something for your model, ask Jim.
All the best
Edited by Nismo 3.2ish
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
