Hi all,
Continuing on from my little flip out when I lost the back in the wet in my Mazda 3 I've noticed the car feels very loose when driving in the wet.
Driving Wakehurst Parkway when it's raining I need to do minimum 10kph under the speed limit around any bends. If I don't then the car feels like it's about to let go.
The tyres are all new; Falkens Azenis on the rear and Hankook on the front but I fear this is more a geometry type issue. Sway bar or similar.
What can I check for or should I go to a suspension joint?
Thanks guys,
Christian
somewhat more seriously though, I'd start by having the alignment checked as something like toe out would definately create that feeling.
It also may simply be the rear tyres are no good in the wet. If they are same size rims I would swap front to rear for a while and see if the problem switches ends
Leading candidates to consider at the rear end:
- Excessive stiffness in the rear. Considering the fact that it's a Mazda 3 and therefore the springs and dampers will be stock and shouldn't be wrongly matched to the front, that leads to thoughts of things that are stiff that shouldn't be. So,
- A bush or bushes that are tight and don't allow rotation where they should,
- A damper that has seized up in some way and prevents bump or rebound stroke,
- Tyre pressures set to something ridiculous,
- Maybe a stuffed wheel bearing or other stuffed bush allowing motion that shouldn't happen. Not so bad as you notice it in the dry, but bad enough to get it moving in the wet.
Thoughts at the front end:
- Broken front ARB link making the front roll stiffness low.
- Buggered front damper perhaps.
Thanks guys!
The car has 90k on it, its a 2008 model and bog stock with perfect service history so while still plausable, i'd argue that worn components wouldn't be likely. Is that a fair assumption?
The shocks are all nice and firm still at least.
Tyre pressures were really high. All tyres have a max 35psi and they were all close to 40 when I got the car (November.)
In the dry its still very 'light' but considerably more sure-footed than in the wet.
I might reverse it up on my ramps today and whack stuff with a hammer (using a rubber mallet) to see if anything is loose or broken.
Could do the front at the same time actually.
Wait...
You don't like your fwd because it feels like it wants to oversteer? I'm failing to see the problem. Any decent fwd steerer will tell you that's the optimum situation. You just counter it with throttle.
Maybe take it to a skid pan and see where it actually does break away. Feeling light and actually breaking traction can be 2 different things.
Otherwise check rear alignment. Fwds are very sensitive to toe changes. Couple with worn steering or bearings (after 90000k you could have worn components) you can find it feeling very skittish.
  • Like 1
So went to jax today to have a chat about this. The rear tyres are 2012 tyres which is slightly on the old side but he reckons they've gone hard. He straight up said that I should replace the rear.
Does this make sense? Not convinced 4 years is too old but can't comment on them being hard.
That's getting on a bit, and some tyres suffer from this more than others. However i wouldnt expect 4 year old tyres to cause this mucn of a problem. Worth swapping front to back (for some reason I thought you'd already tried this) to at least eliminate this option.
Post up your alignment sheet and yes tyres sound old.
Probably hard as shit lol
Here's an idea, buy another Skyline. Wobbly end fixed :)
  • Like 1
soften the rear for more grip in the arse.
NO!
Kepner Tregoe problem solving 101:
If you have a problem where there wasn't previously, find what has changed and undo that change (yes, big over simplification).
I don't think that the rear Springs magically got too stiff by themselves (although some will tell you that being too stiff can lead to a loose rear end, but we'll leave that alone)
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
