Hey guys,
So after almost 2 years, I went back for a touch up tune (same tuner, same dyno) as I'd changed a few things. Got a result I wasn't expecting.
So initial tune:
Stock RB20,
OP6 hypergear highflow
3 inch turbo back with catco cat
china 500X300X75 cooler, with return flow piping (turned 180 degrees with a 75mm radius off drivers side of cooler)
Stock coil packs
Stock actuator, preloaded 5mm.
Z32
Sard 800cc
Nistune.
GTR/z32 fuel pump with feed from battery
Profec b boost controller
Made 240rwkw, full boost (20psi) at 4900, tapering off to 17-18 at 7000rpm.
So things I changed/added
Punched cat.
Apexi front mount kit, 2.5 inch piping, core looks is smaller, bar and plate I believe?
New cooler
v's old
Splitfire coil packs (standard ones started breaking down)
New fuel pump, walbro 255 (old one got noisy)
14.7psi actuator.
Now I had changed the actuator and cat to try and hold boost better up top, which it has done, but response and overall power is down.
Topped out at 230rwkw, and coming on boost around 500rpm later. holding 21ish psi to the redline (graph is in car, I'll try and post it tomorrow). It is holding boost right to the limiter now.
It feels a bit lazier onto boost, but feels better revving right out, (doesn't nose over like before)
With better boost control (and higher boost!) and better spark, less restrictive exhaust, less restrictive cooler piping/cooler (maybe?? haha) I was aiming for a increase, or at least match what I made before.
*I understand the dyno is just a tool, and not back to back testing one thing at a time can be inconclusive, let alone 2 tunes almost 2 years apart, but seat of pants dyno backs up dyno sheet, less response, less power.
Compression test came up between 149-153 across all 6, tuner said mechanically car is good.
Thoughts?
Is my cooler too small? restrictive? Wouldn't have thought it would be a restriction up too 250rwkw
Why did you put a smaller cooler on?
Most of your changes would not lead to better performance - coil packs simply restoring the status quo, if you had enough fuel before a better supply will not help,
Major improvement would be holding boost up but this is countered by smaller FMIC so result is not surprising.
Yeah I've changed wheels, now run a 235 40 18 from a 235 45 17.
I didn't choose the cooler because it was smaller, but did not expect it to affect it as much.
In the hyper gear thread everyone is anti return flow cooler, thought I'd see some gains, even with a slightly smaller ( but "better quality")cooler.
And tbh it was a kinda impulse buy, as it's a cefiro specific kit, which is rare as, had all the brackets and such.
oh well if I can be stuffed I'll put the old core back on, go for a touch up tune. Or start researching decent coolers. The pwr one in the hypergear looks good, but dang, bit pricey
Tyre and wheel sizes make no difference to your power output. Unless you have money to burn just stick your old FMIC on.
If you want a significant power increase save up for a better turbo. At that point you may or may not need a better fmic.
All return flows are not created equal. Some are a lot better than others. Yours might be fine.
Your worried about a 4% drop in power.
There are way too many variables at play to make up that number.
Your seat of pants feeling is most probably due to you being well used to the car.
Also the dyno may be ever so slightly different to before.
Your compression may be a tad lower than before.
My personal opinion is just make do with what you have. Drive it and have fun.
At least you have an RB20 still running sweet. How many threads have littered this forum with people f**king their engines in many different ways.
My 2c take it or leave it.
Cheers.
Your return flow setup you had is nothing like what people are talking about in the hypergear thread
cheers
darren
it is though. stao and a few others mentioned the 180deg bend would be a restriction.
I personally have never used any type of return flow. Plenty of people have made big power on them though. So i don't know.
I'm with Darren, the return flow ones mentioned in the Hypergear thread has the return built into the end tank and is tight, the radius on the one picture isn't so bad, so while it has return flow piping, it's not a return flow cooler (if that makes sense?).
So in saying that to get rid of the "return flow" aspect you could have just replaced the piping, hard to say if the new piping will marry up nicely to the old cooler but it might not be far off?
Its nothing like that stupid bend in the end tank in a "conventional" return flow cooler, your tripping..lol
they can mention whatever they want.....but without testing it means nothing.
cheers
darren
Edited by jet_r31
I'm with all of the monkeys above. That 180° bend might be a restriction compared to a couple of larger radius 90° bends......but it is all good compared to the return flows that actually would be problem. I also concur with the assessment that the old cooler was probably less restrictive.
  • Like 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
