Does anyone know the owner's of said importers.? I know one is phil " iam not a bad guy " lee.
Ones past and present with dodgy dealings are...
* Phil - Edward Lees
* Kong - Dream Car City
* Sam - Master Cars
* Eddie - All Imports and Sports AutoGroup
* Joe - Xtreme Motorsport
* Some Eastern European guy - Prestige Motorsport
* Some Pakistani guy - Ginza
  • Like 4
Haven't they all been involved in dodgy dealings at some point in time?
The only one I can really think of with a clean slate would be Northshore Prestige...
I used to be part of NthShr Prestige. They shut their doors because of these other dealerships.
  • Like 1
So too did JLM.
Once Ginza sent a rusted EVO across for compliance a second time after repainting it.
Once the compliancer recognised the car, poked his screwdriver through the floor and rails, he'd had enough.
He opened the doors on the driver'side, raised the EVO on the hoist to the roof and...
Ever heard a B pillar crack?
Ever heard reinforcement bars detach?
  • Like 3
I reckon 10~15 years too late... most of our beloved R32/33/34 S13/14/15 are quite frankly overpriced cars.
All these pricks have already gotten rich in the past and now just surviving living off what they do best.
  • Like 1
  • 3 weeks later...
What about iron chef?
I hold no ties to the business what so ever. Genuinely curious as he has a good name around most forums.
I have heard nothing bad come from Iron Chef! I havent dealt with them personally but would go there by choice from the good i have heard!
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
