Hey guys,
New to the forum after purchasing an R34 Gt-t.
Im hearing some clunking noises coming from the back, so upon further inspection I can see a fair bit of oil and grime primarily around the LHS flange coming out of the diff.
The teeth on the outside of the flange seem more worn down compared to the RHS.
How do I diagnose if I just have to replace the whole diff, the flange itself or even just seal?
Like I said there is a real solid clunk when taking corners, is at its worst at low speed and with a little on the throttle.
Could this mean a new diff would be in order?
Any advice is appreciated!
Thanks
Managed to contact the owner before myself. He said it went through a few people before him but he didn't or hadn't heard of the diff being welded. From what Ive researched it could be a worn pinion gear. So anyway, found what seems to be a good one for cheap, housing and all. Will drop the old own out and open it up for reference sake.
So got a new diff, filled and ready to go in.
Getting the old one out is proving to be insanely difficult. I'm stuck on the 4 prop shaft bolts connecting up to the diff.
I've managed to get two off. Took about 1.5hrs on each. Literally tried everything. All soaked with WD for a good hour. Jack to apply force to a ring spanner was my best attempt but that didn't seem to get them to budge. The two that did come loose were done with a ring spanner and mallet. Tried for the third but gave up.
Probably the best bet now would be a cheap butane blow torch ?
Any ideas ?
Edited by iamme
Yeah I'll try that. Maybe jack it up higher this time so it has good clearance once on the ground
See if you can get some kind of drift on it and give it a few sharp blows to try to break the seal as it were.
They are 10mm bolts not 20mm, im sure there's no need to grind them off . Piggyback spanners or breaker bar and socket with pipe on it.
Mine are always tight but have always been able to get them. I know theres not alot of room there so need to jack the car up etc to gain the room
What this bloke said - piggy back the spanners.
I struggled when I did my clutch - Piggy backed the spanners and had my brother and I both putting force on them which eventually broke them free.
Actually now i remember, i sacrificed a 14mm spanner for this job. Cut the open-end off leaving just the ring end and shaft, then slide a length of right-sized pipe over shaft to give you a breaker-bar spanner. I call it SST#438
Actually now i remember, i sacrificed a 14mm spanner for this job. Cut the open-end off leaving just the ring end and shaft, then slide a length of right-sized pipe over shaft to give you a breaker-bar spanner. I call it SST#420
Fixed it for you
Gave in. Got out the angle grinder and murdered those little buttholes.
Should have tried the breaker bar spanner. Exactly what I needed. Ah well.
Anyway. Now in search for two more bolts. Would the idea be to hit up a nuts and bolts place and match up the ones I still have?
Ideally use the oem ones from Nissan as you will note the thicker section of the bolt that has no thread, that joins the 2 flanges....but really any high-tensile M10 bolt of the right length with a 14mmm head will do. Bolt shop, or Bunnings will have them.
Headed up to bunnings and talked to a guy that used to work in the auto industry . Bunnings don't sell m10 bolts with 14mm heads. Not that he was aware of anyway.
Got some off a mate in the end.
New diff is in and it drives so much better. No clunk at all. It was really intense before. Will open it up when I get a chance and see what's going on.
So opened it up and it looks like a 2way. Just not sure which one. Guess that would explain the clunk at low speeds around corners lol. As a daily and no engine mods I'm happy with viscous.
Anyone seen a similar two way?
Edited by iamme
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
