well maybe its my conclusion, the cost of mine to be made , ceramic coated and delivered from NZ was equal with 6boost without any coatings or postage so its a win in my mind, customer service was great too...
Have you put a straight edge on the flanges? How a bout a photo of inside the collector?
  • Like 1
Divided 1.01 fo schizzle (edit they don't come 1.06 in divided)
And ram in as much boost as possible, those GTX turbos love boost.
I would dare say a divided 1.01 on a proper twin scroll manifold will destroy a 0.82 and every other -5 -7 -9 -10 GTR out there.. VCT, single, twin scroll and e85 forever in my heart LOL
  • Like 1
Atp make a divided 1.06
Haven't found a 1.01 in a t4
i used ordered a T4 twin scroll single gate for my Borg Warner.
Lifetime warranty (i think 6boost might be limited)
and he also said CRG manifold fit around the factory air con lines, which 6boost do not (my mechanic learnt first hand on his GTR).
$1,190 shipped to Sydney
Not bad
Not bad
This is true. The large pulsation dampener would be touching one of the runners. I slightly bent mine around a bit and then cut the ends and had my AC shop install 2' of rubber AC hose and swivel fittings between them. Forgot to add that. Thanks for reminding me.
FYI the full-race was my first choice but doesn't work with R32 AC compressor NOR the R32 Power Steering...that was out for me since I don't have access to these parts easily in the states and my stuff should work fine.
6boost warranty is useless anyway, my tuner had a car with a heat wrapped 6boost, it crystalized and cracked and rusted and basically fell apart, kyle didn't want to know about it.
He does say if it's heat wrapped it won't be warranted though.
6boost can be funny at times, he made a twin scroll v band manifold for a 180sx I'm putting together. Looked tits and all, till we went to mount the turbo on and couldn't close the bonnet.
Next was that the turbo was clocked so much there was about 1cm to fit on a vband to the rear end and that's it, there wasn't any room for a dump to be constructed.
No dramas, called Kyle explained the lot and he paid for shipping both ways, although it did take a whole month for the fix.
So for me neither shining positive feedback but no negatives either.
  • 5 months later...
On 13 April 2016 at 3:10 PM, niZmO_Man said:
I'd love to see your work. Can you fab up a Gibson manifold?
For what it's worth lads, I been chasing a gts-r manifold for a while now....
Getting over waiting as we all know how rare they are and people asking $2k+ for them when/if they do come up is a bit hard to swallow for something so old...
CRG is fabbing up an R31House style manifold for me in a few weeks. It won't look as flashy because you'll see welds on the joins as it will be made from steam pipe instead of one piece stainless runners. But we had a good ten min chat on the phone yesterday about it and he's very confident he can replicate one! I'll probably make a new thread when I get it...
  • Like 1
When I got my Sinco manifold made I went to see him - he measured the engine bay and I gave him the turbo and wastegate. Fitted first time. I realise not everyone can do that but it is a big plus if you can use a reasonably local fabricator.
Not 6-Boost or CRG but I went with a Fullrace TS coated manifold and down-pipe for my 33gtr.
Very well made and works a treat with the EFR 8374 iwg.  Highly recommend these manifolds.
They are not cheap but if you want quality this is the one  (for me anyway)
Had to cut the down pipe in one spot and re tig it for a perfect tension free fit.   easy fix.
There jig is an R32 which is probably why.
Edited by Meathead
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
