What did you think of New Top Gear?
31 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Top Gear was about the people, not the cars. When the people changed, it wasn't Top Gear any more.
They should have changed the name instead of leaving it tied like a dead albatross round the necks of the of the new presenters.
It's now a curse.
  • Like 1
Top Gear is supposed to be a car show. Early Top Gear had genuine reviews on cars and was totally different to what it became, the presenters ego's made the show about themselves and less and less about cars. Hopefully it goes back to being a car show and Jeremy, Richard and James can do their own thing doing what they did which was entertaining none the less for the most part.
At least Chris Harris is getting more budget for his videos. Pretty much every aspect of the main show is sub par/boring/wasted potential, even down to Matt LeBlanc IMO. He seems to be reading some boring script. At least he's getting paid.
Oh well.
So, Chris Evans will not be returning for Season 2.
I don't think many of the viewers will, either.
Top Gear USA starts again on Monday - That's better than the original Top Gear, seriously funny.
Top Gear USA has been dropped by the History channel in the USA, and apparently BBC is shopping it around for a new network so fingers crossed it get picked up by someone else.
Hopefully Top Gear UK improves from next season. Less advertising the cars and more driving and commenting on the good and bad bits. Still don't understand why Chris Harris was presented as a retard but things should change next year (if it gets another season).
Skimmed ep1, watched ep3 and part of ep4, thought chris harris was ok, everyone but chris evans and matt leblanc really. Segments themselves were good (though mainly saw car review type ones on those episodes, not the road trip etc) but i can see how a roadtrip segment with the before mentioned two would make for poor viewing. Biggest issue i saw was the in studio bits, you'd have a car segment then Matt talking to whoever the presenter was asking stupid questions which didn't really relate to the cars at all
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
