Hey guys,
Had a bit of a look on the forum and I did see the wheel fitment thread, however no one was running/I didn't go through enough pages, to see the fitment I was looking at getting for the car I have.
Does anyone have pictures of 18x9.5 +38 WITHOUT Spacers on an R33 GTST?
Looking to see fitment on both Front & Rear. Really want Enkei RPF1's but I feel like the 18x9.5 +15 will be poke-city...
Then again, I feel like 18x9.5 +38 will sit too far in -_-
Points if they are RPF1 but any 18x9.5 +38 rim will do.
Cheers! & if there is any thread that already has this, please link me to it and I'll take this down!
https://www.sau.com.au/forums/topic/465117-r33-gtst-enkei-rpf1-fitment/
I had 18x 9.5 +30 with rolled guards and had to go 245's all around so i'm guessing + 15 will need some camber adjustments and similar tyre width, GTR spec is 18 x 9.0 +30 which is like the bar as far as a good snug fitment.. beyond that means skinny tyres id say.. but i havnt explored it like the guys on the wheel/tyre thread, the +38 can be done though with 265's as far as ive seen and 10inch wide ..
So you think I could fit:
Front - 18x9.5 +38
Rear - 18x10 +38
And have them inside the guards with good rubber? I don't want it to sit too far inside the guards but I also don't want poke-city -_-
  • 1 year later...
Front - 18x9.5 +38
Rear - 18x10 +38
I have rolled guards on a 34 and a slight pull which is considered to have about the same as a 33 (generally speaking, i.e y ou will also need roll and a pull)
I have 9.5 at the front with +27 and it is perfect. So if you want extended studs and a 10mm spacer this will clear just fine. I have 265's all round but the front can be made to fit, but I think you'll be hitting suspension components stock with that fitment.
In short, doing my maths with my own car leads me to believe you absolutely will need a spacer. Yes, I too wish the RPF1 had a decent offset for GTT/GTST owners in 9.5.
Or even 9+22. This size is also perfect but only comes in 17....
  • 4 weeks later...
Can almost guarantee that 18 x 9.5 +38 will rub on the cast iron knuckle/strut thing (cant remember the name of it for the life of me) on full lock up front, My 18x9.5 +35 (not rpf01s though) required spacers to sit flush and to avoid inside of the rim hitting the cast strut on full lock.. The only real options for decent fitment with the sizes in that chart you have there is 18x9 +35 or 18x8.5 +30 for the front and 18x10 +38 or 18x9.5 +38 for the rear..
  • 4 years later...
On 13/11/2021 at 2:02 PM, shubby0901 said:
Old as thread but what were thoughts about 18x9.5 + 15? Will these poke alot? Obv rolled guards and camber adjustment
Will fit with camber and max 235 tyre size depending on how low you are.
  • 1 year later...
I recently bought 18x9.5 +38 rpf1s for my r34. Just done a test fit front and rear. Rears fit nice. Front hit the brake caliper. This was fitting the rim without a tyre on. Looks like you can get away with 10mm spacer to clear the brakes. Not sure what will happen once I put the tyres on if it’s going to hit anything else on lock
The 18x9 + 35 exist for this reason. - Though for my calcs these will hit the uprights. I have 18x9 +30 and I'm pretty sure I don't have 5mm to spare... more like... 2mm...
9.5+38 is an obvious no, and would slam into the uprights and I'm very suprised that the caliper is the only problem!
  • 4 weeks later...
  • 1 year later...
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
