I was thinking 30 bottom end but I already have forged Pistons and stuff in the 25.. E85 more boost would be good but don't have e85 in Wollongong where I live.. So cams was the optiion and maybe a plenum.. I will do what you said stao and I will look into it! Thanks guys appreciate the feedback!
Another question my tuner said he doesn't want to run more then 20psi on my car because it's on 98 it's safe tuned can I run more?
sell the forged bottom end, and it could nearly pay for the 30 bottom end.
I know how you feel regarding the e85 shortage.
I live in sydney, but still no where near e85.
A flex sensor? There isn't any excuse today.
WMI = Water / Methanol Injection.
Buy WMI kit, fit, fill with water and methanol, give it a little tuning and set up some safeties and boost off into the sunset as if you were running E85, but without any E85. Good compromise solution when you want to push past what is possible on 98 alone.
  • Like 1
My tuner said he doesn't want to run more then 20 to be safe.
Maybe I could go e85 have a eflex sensor and do the 30 bottom end conversion.. If I go 30 bottom end would I need a bigger turbo it has a .67 rear it's the atr45 from hypergear 600hp rated ?
Time for new tuna
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
