The Barra engines are the go, only need to do internals if going 600+hp, they are a high torque motor and a lot of fun, power glide is definitely the go.
I have seen it done but can't remember the guys name.
Only real downside is it won't sound like an RB
Not only do they not sound like an RB. They sound like absolute dick.
Yep definitely don't have the same aggressive scream like RB and 2J its like the tone is stuck inbetween a 6 and 8, hate there sound but awesome performance.
Sounds like you have dicks in your ears.
Some of the comments in this thread are hilarious.
Take a look at a dyno sheet from a mildly tuned Barra 4 litre, and you'll soon realise why they would smack an rb25 like a redheaded step daughter. All while making peak power at about half the revs of the rb25, and hold it to redline.
dont let common sense get in the way of a good internet argument lol
  • Like 1
Interesting. I just got home from a cruise with some mates.
My mate with a tuned Barra got pissed on by an 34 tonight.
That's right, the guy in the 34 had time to stop, flop out is dick and piss on my mates car as he drove past.
Is that hilarious enough for you.
Because I find it bloody funny.
Edited by XGTRX
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
