Hi All,
Recently my A/C would only blow stinking hot air which was awfully uncomfortable to drive in but it's been too cold to have it off. It started off that it was sporadic but eventually got worse. After some soul searching I found out that the part is a the Air Mix/Blend actuator which controls how much fresh air vs heater air comes through the vents.
Tools/Requirements:
- Soldering Iron and Solder
- Assorted Phillips head and flat head screw drivers
- Vice to hold everything
- Power supply to test the motor itself
- Permanent marker to mark existing points
- Sand paper
Difficulty:
- Low
Time Required:
- 1 Hour
Optional:
- Brand new OEM mix actuator
- Used OEM working mix actuator
1) Start by testing the actuator using the diagnostics system - If you have error 26, the problem is most certainly the actuator
http://www.sau.com.au/forums/topic/426605-aircon-diagnostics-r33/
2) Locate the actuator under the drivers side dash to the left
3) Remove cap holding the actuator rod in place, mark the rod for reference and pop the rod out of it's "seat"
4) Disconnect the wiring connector from the mix actuator
5) Remove the three securing screws shown below and take the actuator out of the car
*over to the bench*
6) Mark some reference points on the arm for the actuator - This will make it easier to assemble again later
7) Unscrew the actuator off its mounting bracket
8) Remove the two screws that seal the housing
9) Using a flat head screwdriver gently pry the arm off the actuator
10) Separate the two clips that hold the housing together from the side and gently open the actuator case
11) Remove all of the little gears from the housing and set them aside somewhere they won't roll away
12) Remove the circuit board and motor from the housing to reveal the last large gear with contacts on it
13) Gently bend the contacts upwards to ensure they haven't been worn out and bent over time - Give the contacts a light sand at while you're at it
14) Clean the contact surface on the circuit board - I wasn't sure what sort of grease this was so I left a thin coat on the board anyway
15) Connect a power source to the motor terminals to ensure the motor still functions - If not see the options above or look at a replacement motor (from Jaycar or other electronics stores or eBay)
16) Take your soldering iron and melt the solder on the joints of the board - Take the time to add a bit more solder where necessary
17) If all went well work your way back from step 12 and test the actuator again
Edited by PranK
Copied images from photobucket
  • 8 months later...
does someone have a pic of what its suppose to look like when hooked up on the other side, ive just taken mine apart and put it together and it works when not hooked up to the door but when i hooked it up it wouldnt work, i think its just cause it fell off and now is in the wrong position.
with out it hooked up going full hot makes the arm move to the front of the car.  going full cold makes it move closer to the cabin/gearbox
But i cant seem to get it to line up with the door when i set it too full hot or full cold when i move the door myself
Edited by MatthewT85
  • 3 years later...
  • 4 years later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
