Been a long time lurker here but just joined recently just to get some thoughts & opinions.
So I'm currently in a long-standing dilemma, whether should I build an r32 with a jzx90 1jzgte or just get a toyota jzx100 chaser which has a newer engine. Main purpose will be a reliable daily and will have occasional track/drift days.
If you had the time and money, what would you rather pick between the 2?
Also has anyone done an r32 1jz here? What are your thoughts?
https://www.sau.com.au/forums/topic/466306-r32-1jz-or-jzx100-chaser/
2 hours ago, Cowboy1600 said:
Is it school holidays already?
That necessary?
I have no opinion on this. I do love cool conversions though. I reckon a nice R32 with a 1JZ might be cheaper than a JZX100.
  • Like 1
Wow thank you for all the responses guys ?
Ok, i guess the only unicorn is my daily beater honda hahaha. 1jz does sounds phenomenal.
Have already spoken to a few wreckers and only 1 is available to ship a bunch of jzx90/100 halfcuts, big nom noms!
Its such a challenge but it will be worth it in the end i suppose. Im pretty excited! I'll be posting a build thread in about a month or 2.
  • Like 1
After owning my modified BMW 335i for over 3 years, the Skyline is a phenomenal daily when it comes to servicing costs and repairs (anything 1/2 major breaks on the BMW is like over $1k for the parts and multiply this by 3-4 times if buying locally)...
So much so I parked the BMW for now (currently suffering from ABS failure, leaky turbo seals, adpative head light failure and some other random ECU error codes) and went back to driving the beater Skyline as a daily work horse =D
  • Like 1
The list of errors/faults on my BMW right now... :down:
14051626_10154322699882040_1727254749144294652_n.jpg.1f0dc7fa34d490329f5b4147b86c20d8.jpg
Basically a dead ABS control module causing all sorts of shenanigans, and water getting into one headlight (failed internal seal due to age) frying a control module that controls the fancy 'cornering' lights and a brand new ABS module is over $2k USD from US or about $4k locally from a indy shop for the part alone (and you still need to get it 'coded' with a proper BMW coding tool from dealership or indy shop even if you DIY the install)... :dry:
I must add that my Skyline also suffers from the same 'water getting into head light issue' but because there's no fancy electronic control modules to break there all I did to 'fix' was drill some 'drainage' holes on the bottom of the light assembly to let the water drain out... :cool:
Edited by Mayuri Krab
On 31 August 2016 at 10:58 AM, niZmO_Man said:
^ and that's why I don't understand why people say Skylines are "expensive" and "stuff breaks" all the time. :P
Bmws have always been known to be unreliable shit boxes though, in Germany they buy them cheap and run them into the ground but for some reason they have a prestige status over here
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
